help with 1977 xs500
r sample
This post is 5303 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
I recently acquired a 1977 Yamaha XS500D It ran but very rough and had a top end of about 40 mph. I have cleaned the gas tank. pitcocks & carbs. Replaced needle valves & seats & one float. When replacing the plugs I discovered that one of the heads had been drilled out and a larger plug (diameter) was installed. I replaced the plugs with NGK plugs that according to the numbering system are the same depth and heat range.
It finally ran good after I replaced the points and condenser. But only for about 20-25 miles then it started doing the same thing.
I suspect the condenser is the problem, since the points still look good. Can anyone explain what might be ruining my condenser?
Thanks,
Rusty
Thanks,
Rusty
do the contact breakers spark with the engine running? if so either the condensor is not earthed properly or is faulty. if there is no sparking, then i would suggest
a) timing check
b)a carbs strip down and thorough clean with ultrasonic tank
drewps
a) timing check
drewps
  • 1 month later...
