DT 175MX rear wheel noise
col68
This post is 5490 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
Is there any clever chaps out there who can shed some light on this problem been out on the old girl today and the rear wheel has developed a CLICKING sound but not all the time have fitted new rear wheel and bearings and shoes/chain/sprockets couple of months ago wont CLICK while on blocks surprise surprise any ideas
Chain is to tight when your on the bike
Sounds like it, needs fixing quick too as the output shaft bearing in the motor requires a TOTAL strip to change. An over tight chain will wreck it quick as you like, a couple of runs if your unlucky.
Sounds like it, needs fixing quick too as the output shaft bearing in the motor requires a TOTAL strip to change. An over tight chain will wreck it quick as you like, a couple of runs if your unlucky.have checked chain doesnt seem to be too tight but will adjust again thanks for your help fellas
You say you have checked the chain and it seems ok, have you made sure the tensioner is working ok, if that has siezed or started to sieze that will make the chain too tight but appear ok.
Other than that hows the wheel alignment?
