Inline Fuel Filter on FJ1200
kelpike
This post is 5540 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
It shouldn't make a difference as long as the hoses aren't kinked.
are you sure the filter was installed with the correct flow direction?, it could be that there is some shi*e in your fuel tap and the filter is restricting the flow to the carbs.
Is the Fuel pump working correctly as it should pump the fuel, thus pulling it from the tank to the carbs. I had lots of problems with my fuel pump and ended up ditching it. I now run a gravity feed with in-line filter(on its side under tank) and dont have any problems.
Adam.
