Bolt sizes
stevie16v
This post is 5639 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
Sorry Steve but dont know what youre on about!! :blink:
I went to change the brake fluid, when i went to undo the bleed nipple, the head just sheered off (i had used tons of wd40) but to no avail. It however is still closed so no problem there. I was advised to get one of these http://cgi.ebay.co.uk/ws/eBayISAPI.dll?Vie...rksid=p3907.m29
It goes on where the brake hose goes into the caliper and replaces the standard union bolt, allowing the bleed nipple. Is that a bit clearer?
I may be wrong here but dosn't the brake lines go into the bottom of the caliper??
If it does you will not be able to bleed the air out as it is at the top of the caliper.
