bodgley Posted July 30, 2008 Share Posted July 30, 2008 The emulsion tubes on of my carbs are so badlly worn that you can see it with the naked eye. It has been fitted with dynojet needles and these may or may not be worn, so I am replacing the lot with standard main jets and needles. Does anyone know what position the E-clip should be on standard needles? The Haynes manual states that you should note the position of the clip before taking it to bits, which is not very helpful. In case anyone else needs carb spares NRP are so much cheaper than Mr Yamaha. Regards Mark. Link to comment Share on other sites More sharing options...
WiCkY Posted July 31, 2008 Share Posted July 31, 2008 use 'Factory Pro' needles which will outlast the stock yam needles by a helluva lot. Link to comment Share on other sites More sharing options...
bodgley Posted July 31, 2008 Author Share Posted July 31, 2008 The emulsion tubes on of my carbs are so badlly worn that you can see it with the naked eye. It has been fitted with dynojet needles and these may or may not be worn, so I am replacing the lot with standard main jets and needles. Does anyone know what position the E-clip should be on standard needles? The Haynes manual states that you should note the position of the clip before taking it to bits, which is not very helpful. In case anyone else needs carb spares NRP are so much cheaper than Mr Yamaha. Regards Mark. Link to comment Share on other sites More sharing options...
bodgley Posted July 31, 2008 Author Share Posted July 31, 2008 use 'Factory Pro' needles which will outlast the stock yam needles by a helluva lot. Factory Pro needles sound like a good idea, but I have already bought some standard needles. Thanks for your advice, Mark. Link to comment Share on other sites More sharing options...
