blackhat250
  1. Look what I"v stumbled across today Local too , the guy has a 175mx also , and a purple fs1E , am to get first refusal when he sells,, The 250 has only 2000mls on her, the paint is only bad bit,, original 1 mirror too,
  2. blackhat250 replied to sniff6's topic in Yamabyss
    Yip " he manipulates you " like a detective,, cross examiner
  3. Wtf,,,
  4. I think the Tracer is called The FJ09 . look at the fairing .. Yeh " sports orientated show tho,,,
  5. Video is an hour long, so skip to the models you like,, http://youtu.be/lQgJ79WYcAc
  6. Relax matt. its a non points charge,,, if your licence is clean that's all the insurance are interested in,
  7. Blood ell " what was the value...I mean its second hand,,, V.A.T. ?
  8. No " the nut tightens the sprocket against a shoulder on drive shaft , not the seal, may have damaged the new seal,
  9. The float valves are same in most Mikuni carbs ,, I swapped a N,O,S ts Suzuki valve into the DTcarb,, both carbs were Mikuni v28"s..
  10. Hi " ray , good luck with the test,,
  11. Dosna matter, I had a uk Zed900.[ lost docs] still need a N.O.V.A. ,all done online, you need to register yoursell on HMRC, [GATEWAY], Fill form online,,just tell the truth, put sellers name, and amount paid,[ ahem] are you a dealer - no.. you"l get an email 7 days with number, print this , and send off,.
  12. Foams " your a dinosaur , ,,, funny thing the other week, I came up behind some old yank v8 saloon ,[ retro1970s] at the lights, it a had a rear spoiler like a set of goal posts, , so we set off,[ que infront of us,] till we exit the city limits, Well he gives it some big licks, [ all noise] and I just had to pass him in a flash, honestly I think the DT250 wudda gubbed him, Buy up them 2strokes , if electric takes over,,,old gas guzzlers will be icons,,
  13. Hi kirito " good wee bikes them, 2strokes, it was the states that outlawed 2 strokes in the 1970s, and jap manufactures swung to 4 strokes, its history now,, get roaded you"l love it,,
  14. Brilliant, that's normal [ choke kills engine as it warms =floods] now back out the idle screw till revs drop, if they remain high , slacken throttle cable , .if this don't work , take out the slide,[ could be in wrong] ,,
  15. blackhat250 replied to dt502001's topic in General
    If the nails thumpin, get a 3mm drill and twist it on the nail ,till it bleeds, pressure release . don't try the cordless
  16. Yeh dutch,,, make shure the obvious is all working, and tyres, I"v been picked up for split pins before
  17. Aye dry heat,,,micky was a one hit wonder,,, secondhand is best OEM from dry states ,
  18. Sumin bent about this,,,
  19. Burst your bubble" but looks like the Yam reels him in by the end, http://youtu.be/KeHU2BzTJJU
  20. HI Jason " we had the TY50p over here, restricted to 30mph,,,,
  21. Speedo is not even an M.O.T. Item, so a kill switch shouldna be,, has to start to hear exhaust, but nowt about killing engine,,
  22. Lighting coil is on the stator plate,, usually Yellow . yellow/white, wires,,
  23. If volume of sales slump on fuel. they"l Tax the electicity Too ,,
  24. Superb . off roaders,
