blackhat250
  1. Are the new bars taller or wider than the old bars ?
  2. it was more of a Alfred Hitchcock suspense movie.
  3. Hi joe,, that was an essay , not an intro,,, . i" l read the workshop question once its been moved,,
  4. Hi triplux" were 2 strokers too , get pics up of the RZ"
  5. Aye kev " you would make a right polltician , rig the poll
  6. Just pull the whole connector apart, the other wires are for lights etc. they"re may be a separate bullet connector for kill switch on bar,
  7. Aye rick , get the clutch cover off, you"l see what jamming it, And the oil out the breather ,sounds like gearbox over filled,,
  8. Aye tommo" looks good ,,, ,, kevs design - for the Satin slaves,,,,
  9. Hi slick" scroll down to the Custom section ,lots of draggy info there ...
  10. Welcome john" wheres about you located , thers a good few forums Air-cooled / and 2stroke forum, a few of us are on them too, lots of info,
  11. blackhat250 replied to Stef-c-'s topic in Classics
    Another great story john,, , hows about some pics,,,,
  12. Nice merv" saw 1 silver 250 ,,, in 1978 i think,,, wern"t popular in silver,,
  13. Hi adam, glad your enjoying the Yam,,, summer is on its way,,,
  14. After you"ve got the timing / key issues fixed, disconnect the Black/white wires from kill switch and ignition. these ground the CDI, Should spark then.
  15. Hi weegie,,, i thot you was from Glasgow , get some pics up of the YPVS....
  16. On yer bike tasky " . welcome Praed,
  17. blackhat250 replied to yammycafe's topic in Projects
    Aye cafe" try and use the airbox, as pods are the scurge of running probs,, , Who"s your dad , user name i mean,
  18. It shud be 2N4 or 2A6 . clean frame and read again,,
  19. Hi jesse" is it a points model or CDI,,,,,, lets get a spark here first,, or power to cdi. clean ALL connections,, then move to coil, then trim the lead, - new plug,,,
  20. Hi King.P. it will run with knackered crankseals, you say ran for 5 mins , was this with choke on? did it run with choke off ,? you"l not find fuel behind flywheel ,as it will be sucking air in,, Dry plug - defo pllot or choke jet clogged,,, how is the spark,,, oh change the plug , as they can fail when warm,,,if old, And its a Liquid cooled,,,is there a knackered head gasket,,, all these thing need illiminated, U tube will show you a leak down test for crankseals,,
  21. L reg is the last black/ silver in UK, but my TS250 is 1974 ,[ M] i have a black plate, as , On the V5 it says Manufactured 1972. Police tailed me last year , never pulled me,, ,
  22. blackhat250 replied to yammycafe's topic in Projects
    Hi yamycaffe" , surf the projects section see if thers a solution, And yeh the forum has been funny latley ,,
  23. Yip ray" that jam was Hydrolic lock . seen triples on forum, when the oil pump and check valve pass oil . and when try to start = bent con rod. your on the right track , as them guys said,, What beats me is" the overflow should prevent the fuel entering cylinder , But my old iliminator did the same, smell the oil , it will be contaminated,,,and will be diluted = poor lube,
  24. Good to see your back on track,, front fenders are a minefield for DTs" and AT"s - Ct"s
