blackhat250
  1. blackhat250 replied to wild foamy's topic in Projects
    You like your Hondoo"s foams,,, you and Neo can share a tent,,,,
  2. Welcome , from the sunshine state i see,,,
  3. I knew Honda"s were good for summat,,
  4. Aye dt" click share below the video on Utube, the big box will light up blue, just copy this box,, or EMBED ,, work too .
  5. Flood gates are open then,,,, Jim you a jammy sod
  6. Was that his hole finger,,,, or the 1 next to it,,,,
  7. Neo " you"ve got a fetish,,,
  8. Never been into Spectating ,,, get involved type,,
  9. Ok jim,,, just drop the front forks first ,,say 35mm , and see the difference , then look for shocks , but you"l need to search,,after measuring,, as buying straight repros, will be same leanth, or Hagon will make to suit,,£££££ "s tho..
  10. "They"rs life jim but not as we know it " Yeh jim , you can slip the front forks down thru the clamps, , And measure the rear shocks , and order some repro shocks 30mm less in leanth, thers lots on ebay,,and are quite stiff, so give better than standard handling,,
  11. Check the fuel tank for holes to mac , a mate painted an old Lc tank , only for it to blister along the seams ,,,
  12. It is jim,,, welcome,,, av been to Wrexham once,,,
  13. Confusing, L/h side cover is generator side,,[ sitting on bike] ..
  14. Welcome bolton,, , replied to you Quest, 2002 DT175 ,,,,,
  15. Hi bolton..i was unaware the there were DT175"s As new as this, Any way,, why did it seize the first time, did you find that problem, ie is the oil pump working,, as i think you are low on compression again,, as its got spark, fuel.. and it did bump start,
  16. Great collection,,, i"v had all of these models,, bar the 512 Dt 250. Back lights and fenders are different,, Your DT125 is a twinshock ,not an MX,,,,[ as in avitar list]...
  17. Naw lassy" its the Super unleaded fuel , expensive stuff at pumps,,, V- power etc....
  18. Placebo " , Is there any proof ,,,of gains,,, i know Av-gas runs cooler,,,,its high octane ..
  19. blackhat250 replied to kristianybr's topic in The Bar
    Check the oil weekly,, even after short runs,,, as its burning oil, new piston will not stop this,, unless you rebored it ,
  20. What oil did you put in transmission?
  21. Hi sam, R6 is a quick machine,,, you"l have a 33bhp restricted bike first tho..eh.
  22. Did you replace the head gasket, and was it OEM, gasket, ?
  23. Hi luke" yeh get involved in the threads,, were all still learning,,
  24. Tuesday
