blackhat250
  1. Reading / Cambridgeshire ? I thought you"d be mega fast uploads ,,,
  2. It probably has a light flywheel, and wont tick over @ 1000 rpm,,,,, 2 sparks then nowt , ?
  3. Hi slow coach " , short and sweet eh,,,
  4. blackhat250 replied to Unk's topic in Projects
    Bargain,,,,,get in there,,,,,
  5. Yeh ask any kid in Liverpool with a shell suit .... Its just I gave out instructions of ignition on here before, and was shot down in flames,,,
  6. Hi drifter " its easy to put a swich on , but with bike thieves reading these pages ,best not give the wiring of it...
  7. A new meaning to the word Slabside can you see anyone tucking below that screen,,
  8. blackhat250 replied to Unk's topic in Projects
    Intresing this,, been reading, The TX750 Yamaha had a chain driven balancer shaft, with no tensioner , what a foopa ,
  9. Did you see film " deliverance ? hes gonna get u ,,,
  10. Yeh great intro.. . side casing off and check the shift pawl first, little spring located or not,, post up a thread on this [workshop,,,]
  11. blackhat250 replied to Unk's topic in Projects
    Yeh them four strokes will make good Anchor"s for the ferry,, ,,, Just curious " the super[wet] dream had a balancer shaft in ther 250, canna see one in the XS ? I see its 180 degree crank, the brits were 360 ,, I need some answers from you 4 bangers,,
  12. Yeh " the exhaust is the hottest part,, it will burn off, hows she running now,,
  13. Tommo" Your gonna squeel like a pigee ,when he sees you next,, ,
  14. Drewp"s your a smak-head, ... my old H2 did it badly on white lines, ,, put on Avon road riders , transformed, ,, Modern rubber needs higher presures ,,,
  15. Steaming ? you mean smoke, is there a leak, or a spill of fluid on it ?
  16. That thing looks great,, nice wheels,,, well done,,
  17. The spark was inside the flywheel yeh ? is yours a points model,?
  18. Your lucky then, pull the plug and see if wet,,
  19. Yip, you could bend the conrod, [ hydrolock] .this is the result of the blocked overflow, the fuel has been as high as its ran thru carb into cases,,,, you should see fuel squirt out plug hole,[ when kicked over], leave it for a night - dry plug and should start ,,
  20. Bugger " you"ve filled the crankcase with fuel,, take out the spark plug and kick over , do not kick over with plug in,,,
  21. Very nice .I like that style of bike,,,not popular over here, thers 1 other member with a radian .
  22. Mind give the exhaust a clean out first as tone said , , main bearings are usually a rumble more than a knock,,
  23. Clip on the needle , there be 4 grooves in needle , move clip up 1 . that drops needle farther into the needle jet, [ leaner] https://www.youtube.com/watch?v=KXxxJrA5hNY
  24. Weak detent spring, should be located under engine ,looks like another sump plug ,only smaller angled sometimes..
  25. weak detent spring. pushes ball into shift drum at neutral , this also earths the neutral light,,, ,,,welcome..
