dt502001
Everything posted by dt502001
  1. dt502001 replied to jimmy's post in a topic in General
    Verry nice something about thoes old triumps they look more modern. Is it still 6v points or has someone got it fixed up with a elec ignition. 12v?
  2. Before even thinking of selling it for parts as you rarely end up selling allof the bike in parts .if your not into restoring it put up a reserve of say 800.00 and try selling it whole thenext person who does want to restor it would have what they need to make a proper bike. That said I would first pull the heads off and soak the pistons in desiel fuel the most likely reson it's seized is the piston are stuck from rust and if they are not broken most likely could be used again with a good cleaning and fresh rings. It looks like you have a whole bike minus a side plate so if your not in kind of rush to make the bike perfect it just looks like alot of cleaning polishing and paint. As for profit after restoration more like you will spend more but if you hang on to it for another 20 yrs then well who knows. I would do the resto and just ride it now and then for the cool factor
  3. dt502001 replied to The Flying Scot's post in a topic in Projects
    Just a quick question doesn`t anyone rebuild cylinders over there cause we have lots of places that do it here.for around 200 bucks and personaly I find re worked barrels are heat stressed and tend to run better longer The bike looks nice so far looking foward to the finished bike posted
  4. New never hurts but might not be nessary. Spend a fewbucks on a none contact temp gun and check the temps all is prob ok and your woring about nothing John you may never hear the fan run in the climate you live in ..it`s more of a back up for high temps that you guys realy never see. here it`s been 30 c for weeks not a barely drop of rain for a month nights 25c we need fans just to keep the bike from over heating in traffic but they go off soon after you get roling. anyway let everyone know how you make out
  5. dt502001 replied to Grouch's post in a topic in The Bar
    Not realy matching tires is a good thing as the were made to work with eachother. But different tires work better in different ways so mixing and maching can only work if you know what tires work the way you like them too. Them demons work very well in the rain in my op.but suck in the dry again my op. Battel axe dry good ...wet EHH. just my opinon. I can only say what I know and how the tires work for me. Not what would work for you. But I have always liked metzellers me33 on a light bike on the front dry or wet they come up to temp quick and push watter out well as they have lots of tread blocks groves. Best bet to find the right tire is look at every bike like yours and see who is running what if most run a certian brand type then it cant be that bad ..unless they are all cheap buggers. A trip to the local track will unfold a great deal of info talk to the guys running your bike.
  6. dt502001 replied to Sir Puma's post in a topic in New Members Welcome Area
    Hi Marcus While this should be 2 posts 1 in the new mebers section and 1 in workshop to keep the thread going .I will say this the float needle & seat should be checked as well the floats themself. Just to check they actualy float old bike like that... the floats get holes in them and no longer float. and the seat/needle can't stop the fuel. If the bike was stored with fuel and tap open and the floats didn't stop it from running in then It only has 1 place to go down through the carb and into the motor ..past the rings and straight into the bottem end of the motor. Run and re flush the oil afterwarming up O yea Welcome to the YOC
  7. dt502001 replied to Grouch's post in a topic in The Bar
    LOL nope .... not a care in the world about bikers ...only the sewers..... they seem to always put them in the most inaproiapte places. On that note buy realy good tires the best you can NOT afford.......... the ones that cost 2x as much as you make in a month, then they will sort of stick on man holes, at least give you a fighting chance.. I have said this before.... If i had to put up with the rain like you guys have to I would be running intremediate DOT.. cert..race rain tires FUCK the cops. the dam things stick like glue.And my life is worth the extra cost of replacing tires often. 3 most important things good bucket on your head,,,,,,,,,,,,,,good leathers and ..... WAIT for it ..... ......TIRES!!!! # 1 You wont need the bucket or leathers if you have good tires and ride with your head NOT your Balls
  8. The thermostat must be opening if not then it would boil over or run cold if stuck open and the fan wouldn't need to come on check the eng temp with a temp gun. The white chunky stuff does it keep comming back? or did you just ride through some stuff on the road
  9. K seal form Solv-tec works very well www.solv-tec.com don't bother if the coolant is mixed in the oil but if its only blowing out it will seal it in about 20min run time
  10. If it leasking out there won't be coolant in the oil most likely
  11. A hour is more than long enought to trip the fan on ..probably what is happening is air is traped arund the switches not alowing them to be heated by coolant. is the thermostat opening? If the white chunky stuff is coolant you have to be loosing coolant from the system. You can put some head gasket in a bottle to temporaly fix it.
  12. Not nessarly ..water boils at 130f and the cooling system operates at `180f the switch probably wont close untill 185f or higher to turn the fan on some dont come on untill 210.
  13. dt502001 replied to Vaughan's post in a topic in Yamaha Workshop
    That was my thought leaking crank seals. I use propane to check O next time can you change your font it's realy hard to read tiny little words
  14. dt502001 replied to Mason's post in a topic in The Bar
    Thames valley riders for mx and huron riders assoation for ice and enduro events.with my son. They host all the events and to race in them you have to be a member Have a few buddys that when we can get together we do no destination rides just point and go find new roads. But mainly I ride alone I like to go for long rides and most can't handel 12-16 hrs in the saddel,I cheat though I have a nice gell pad in my seat forms perfect to my butt.Most of the time I will ride with others that I meet along the way but keep going when they stop.
  15. dt502001 replied to boon's post in a topic in New Members Welcome Area
    Hey boon welcom to the yoc grate intro.If I read the flyer right its free to attend.
  16. dt502001 replied to Grouch's post in a topic in Yamaha Workshop
    Not good you got to check the run out on the hub and disc......... even the new one afeter installing something is wrong...I run brakes ??? I don't know how many years and I am HARD on them. Stoppies are so much fun ..I keep filping back and forth between SBS and EBC but always sintered bronze medium grade. I can dry them up quick and life is ok by me. but NO way I can burn up a set in a month let alone 3 in a year..... you need to look at your brakes very closely ..........something must be stuck
  17. dt502001 replied to DirtyDT's post in a topic in Yamabyss
    Ehmmm dt first rule of paint test first on hidden surface RIGHT????? Sorry to rub it in but ???
  18. dt502001 replied to dt502001's post in a topic in Video Section
    Sadist realy to torcher people with the video ..he realy knew how to make you drool over the collectables fireing them up 1 at a time GRRRRRRRRRRRRRRRRRRRR ...and to think he knew about them for 30 or so years.... bet that hardly ends up in his collection.. by not making the list of For sale
  19. Hi Mike welcom to the YOC why not post in workshop how you went about flashing the puter without the power comander I'm interested and sure others are too.
  20. dt502001 posted a post in a topic in Video Section
    Now this guy could collect RARE stuff 100+ yr old all original well worth the watch.The guy could have easly been worth milions. I would have loved to been there as they pulled suff out http://www.coolestone.com/media/3728/American039%3bs-Ultimate-Barn-find/
  21. dt502001 replied to Lukyboi's post in a topic in The Bar
    I hate the things I take a punch and knock the pin out use a regular torxs throw them away and put in allen bolts.
  22. dt502001 replied to DirtyDT's post in a topic in Projects
    Looks like a done bike to me pop on the fender and wala time to ride ...so off you go "get er done" no time to be monkeying around here
  23. dt502001 replied to Noise's post in a topic in Yamabyss
    LMAO He was prety ugly his girlfriend is prob a fat sow
  24. dt502001 replied to GeoffH's post in a topic in New Members Welcome Area
    My appoliges just sounded realy sketchy needing all the parts one would need to convert a stolen bike into a ridable bike. The projects page could use some new picts
  25. Your looking at the eng the right way. any chance you can post a picture of your heads problem It may be fixable,if it just the threads that are striped out you can put a heli coil in.. if part of the head is broke out any good welder can build it back and then drill and tap new threads.And file it back flat and even with the rest of the head. Dragstar and classic same eng. Most likely why you can't find a front is cause they get smashed up in accidents
