Everything posted by Alex
MT-09 Rear Axle High Torque, Torque to Infinity
Well, my whining output shaft noise had been getting worse, so I took the bike to the garage to get an idea of the cost. They did what I’d been too lazy to do, stripped the back wheel and sprocket cover. After removing the front sprocket, it was clear the sprocket had worn one side quite a bit, hadn’t been aligned properly. It was also quite worn, I didnt even think to check this as the chain and sprockets had only done about 5k km on it. Obv crappy material. Thankfully, the output shaft spun freely with no clicking, phew! That was great to see. Turns out the rear wheel bearing was the main culprit, followed by the front sprocket, which explains why I thought the noise was coming from the front. I’m honestly so relieved to be wrong, a wheel bearing, chain, and sprocket are a lot better than having to pull the engine and split the gearbox casing. Hate to think what that would’ve cost! It’s booked in for Monday for some much needed love and care, something I embarrassingly haven’t given it for a while.
Kettenmax Premium Motorbike Chain Cleaner
Ease of Use: The Kettenmax Premium is so user-friendly, you might mistake it for your new best friend. The instructions are clearer than the sky on a perfect riding day, making assembly easier than finding an excuse to hit the open road. However, don't be fooled into thinking this is a one-handed, "look ma, no hands!" operation. The chain cleaner has a tendency to dance around during use, requiring you to steady it with one hand while wielding your cleaning solution like a master swordsman with the other. A minor inconvenience, but it's all part of the bonding experience with your beloved two-wheeled steed. Premium Features: The Kettenmax Premium outshines its standard sibling like a high-performance engine roaring past a moped. With four different brush sizes that eliminate the need for arts and crafts time (no more cutting brushes!), you can ensure your chain is treated with the utmost care and precision, regardless of its size. The improved brush system is like a tiny army of scrubbing warriors, fighting against the forces of dirt and grime to restore your chain to its former glory. And let's not forget the pièce de résistance: the bag that catches excess cleaner and lubricant like a skilled juggler. Gone are the days of the sad little hose dripping on your driveway, making way for a more convenient and cleaner experience, ensuring your workspace remains as immaculate as your chain. Cleaning Performance: The cleaning brushes on the Kettenmax Premium are more relentless than a biker who's had one too many cups of coffee. They fearlessly tackle built-up dirt and grime, leaving no stone unturned or chain link uncleaned. However, like the end of a thrilling ride, the real challenge begins when it's time to clean the Kettenmax Premium itself. The device drips cleaner and the small crevices are a magnet for grime, making cleaning the device a bit of a wild goose chase. But hey, nobody ever said the life of a biker was easy! Lubrication Performance: Picture this: after an epic clash with dirt and grime, your chain emerges victorious, ready for the grand finale. It's time to pamper your valiant chain with the smooth caress of lubricant. But wait! Why must you first clean the Kettenmax before diving into the world of lubrication? Fear not, for even though cleaning the device is a bit of a challenge, keeping the inside dirty and using it solely for cleaning doesn't hamper its effectiveness. After all, spraying lubricant on your chain is like icing on a cake – effortless and oh-so-satisfying – and doesn't require a fancy contraption to get the job done. So, go forth and spray lubricant direct from a can with confidence, knowing that you've got the best of both worlds at your fingertips. Quality and Durability: The Kettenmax Premium is well built, with a thick high-quality plastic. The brushes seem like they'll be good for a years typical riding. In conclusion, if you're looking for a chain cleaning device that's as reliable as your trusty leather jacket and has a personality to match, look no further this is the best I've come across. With its ease of use and impressive cleaning, it's a match made in biker heaven. Just remember to hold onto it like you would your motorcycle on a winding mountain road, and be prepared for a little post-cleaning. RATING ★★★★☆ 4 out of 5 stars – the Kettenmax Premium is like a good hair day for your motorcycle chain. Not quite perfection, but pretty darn close! Apology: Oops, my bad! I was so engrossed in the cleaning process that I forgot to snap some before pics. But fear not, dear readers, I promise to remember next time I need to spruce up my dirty chain. I'll even throw in a bonus video of the cleaner doing its thing.
US custom yamaha xs250 rebuild.
The slack should be between 5-7mm, looks like you need a new chain and sprockets for the starter. It's probably rattling already, and may risk jumping which could crack the housing.
My Experience with IAM Advance Rider Training
Regulation 27 (Restrictions on the use of lamps) https://www.legislation.gov.uk/uksi/1989/1796/regulation/27 The Highway Code says to use dipped headlights in daylight if visibility is reduced, and to only use main beam when it won’t dazzle others. Using main beam in the day isn’t illegal per se, the law says main beam headlights must not be used if they cause dazzle or discomfort to other road users. During bright daylight, they usually won’t dazzle, but in lower light or if you’re directly behind someone, they can. So technically it’s not outright banned, but if it’s judged to be dazzling, it can be an offence.
True but there is less force on the output shaft as much lower torque. I was hoping I may hear a difference to identify the fault, but windnoise and bike noise make it too hard.
Well it's been almost two weeks of me driving like an ass with my full beam on, well day time only. Haven't had one person pull out yet. Obvisouly on a small time line and a sample size of one this could be totally irrelevant. But feels like people are seeing me easier.
Guess it's one of those things, it depends. Where I live I don't get the luxury of nice open roads, I'm about 10km from the city so my riding is nearly all city type riding. I don't think IAM would run courses in this type of enviroment. I just try and ride defensively always.
Yeah I'm scared to take it for the next service, and can't be assed to take the chain off and spin the wheel to check. I've tried pulling the clutch in when riding and the sound doesn't appear to change that much, so hopefully it is the wheel bearing.
The wheel bearings are easy to do, I'm just not entirely confident it's not the output shaft bearings. Fingers crossed it's the wheel bearings. Just coming up to 25k now, that's KM. I was thinking normal lifespan would be 40-50k. I do ride my bike in all weather though and Sydney can be very humid which could have accelerated wear.
I read the book as a PDF a long time ago, the part which struck me the most saccadic masking which I never knew about. Really explains those moments when you're about to pull out of a junction thinking it's open and brake oh there's a car you didn't see. Makes you realise how much easier this is to occur to bike riders when we're a third of the size. Video here explains it, apparantly we're all completly blind for about 40mins a day due to this masking. Our vision is almost an illusion. https://www.youtube.com/watch?v=gOz7buiQ7G0 Oh forgot to add I spoke to someone last week who explained the concept of progression makes you safer because it forces you to plan ahead, commit to actions with confidence, reduce unpredictability, and stay in control of the traffic situation. It should be about smooth, safe efficiency, not speed for its own sake.
My bike has LED lights, but you've made me think about having extra lighting. I might ride with lights on full beam in the day and see if that makes any difference. I think half the time they do see me, just don't care, or underestimate size/speed etc.
Well bike is all back and working normally. Sorry haven't had time to come back and update. The MT does not have reinforced hoses from the water pump, so it turned out to be normal behavior and it was nothing to worry about. Guess this is an issue when you take your bike to a non yamaha garage. I've since read online of people fitting aftermarket anti collapse hoses. But from playing further it doesn't collapse enough at low temperature to cause an issue, and once at temperature and the thermostat is open there isn't an issue. Strange that they'd save a few $ and not have anti collapse hose. As for the problem they have no idea, the ECU showed ignition coil issues and it stalling. They reset the ECU and it was fine. No idea what caused the issue or in fact what it was. Had to change out the plugs as one had failed, over heated in dry engine trying to start it so much. Next job I keep putting off is a whining bearing noise which has been getting worse over the last few months. I'm hoping it's just the rear wheel bearing and not the output shaft. Guess that one will be a massive job if so. The tilt sensor was from an accident I had last year. Surprised Yamaha didn't clear this when it was being repaired.
I use my bike daily for commuting to work so get the worst of the issues due to riding at peak hours through a city. Three main culprits, pulling out from junctions even when they bloody see me, pulling out on roundabouts very frequently i think the drivers think they'll fit along side me, and lastly quickly pulling out of stationary traffic into the lane i'm in as they think there;s a space, or even if it's a bus lane and I'm in, they decide to swerve out quickly in to the bus lane as they're turning left in a few hundred meters.
Hello, old biker returns.
Welcome aboard, look forward to following what you go wtih.
My uncle was a Police bike trainer, he must have been a contractor as he wasn't a police officer. He also taught the BMF Blue Riband Instuctors. My Auntie made me go for a few rides with him when I first got into riding, I don't remember his philosophy making me ride faster than I was comfortable with. It was mostly about defensive riding, observation, prediction etc. as well as the obvious things like not sitting in blind spots, riding through corners etc. I then got onto doing a Police Bikesafe course and that was fantastic. The police wanted you to ride at your normal pace, weren't interested in you speeding, they said they want to see you how you really ride and would make you safer. I was a bit of a moron then as was in my mid 20s, and was always speeding, the police followed me and talked to me after about what I was doing what was dangerous, what I could do better, and what I was doing well etc. It was the best course I've ever done. I did another course, can't remember if it was BMF, IAB etc, but they were teaching the SMIDSY maneuver, essentially wiggling your handle bars before junctions to ensure car drivers see you. Although the instructors could do it safely, confidently and smoothly, I never could. I still today don't do it after trying quite a bit, I still feel the risk in wobbling your bars before a junction is more likely to be a risk than stopping when the car pulls out. Obvisouly depends on the road and conditions etc. Now in Australia, training sucks, it's all track based. I've done three track sessions with the Honda training centre which uses an ex police training track. Now the training is great, but it only applies to roads with zero traffic and junctions. I really wish they had proper road based training out here. Just thought, one key thing my uncle always tried to drum into me. Always practice emergency stops. Which reminds me I haven't practiced it since my last bike course about two years ago.
Well, it all went downhill after changing the axle. Went to start the bike up afterwards, turned over fine, but wouldn’t fire. Cranked plenty, but just no start. I had a feeling it might’ve had some water ingress, as I’d washed it before working on the axle. Pulled the tank and airbox off, everything looked bone dry. Took the coils off just in case, also completely dry. Put it all back together and tried a few wide-open throttle starts to clear any flooding. Waited a few minutes and tried again normally... pt pt pt bang stop. It almost started. Hooked up the OBD reader, no stored fault codes. Then, suddenly: click click click. Wouldn’t even try to crank. Thought maybe the battery was on its way out, so I charged it for a couple of hours, full charge. Still just click click click. Figured maybe the starter fuse had blown. At that point I gave up and booked it in with the local bike shop. Garage called later. They wanted to know a bit more history, said they weren’t 100% sure what happened, but they got it started using an external battery. No idea why it wouldn't start with me. But then they asked me something worrying: “Has it been overheating?” Not that I know of. Then again, I only ride it 30–40 minutes at a time commuting, so if it had a slow overheating issue, maybe I never noticed. They told me the coolant hoses were collapsing, and that with the radiator cap off, coolant shoots out when you rev it. They compression-tested all three cylinders, all came back fine. So now I'm hoping it's just the head gasket, and not a warped head or cracked block. It's only done 23,000 km, so hoping it’s repairable. A sad weekend for sure. Down 2hrs diagnostics so far.
electric motorbikes
Well glad you're ok, that could have easily been more serious, lucky. I've had a couple of near hits similar to that, on last year, even though technically it's still the other driver fault, in hindsight I've realised I could have avoided it. I still do the ocassaional thing and immeidatley after think why did I do that. I think everyone has that moment in time, when they're in a rush, stressed, distracted, wrong mindset etc we just need to work on reducing these times and be more aware of our mindset when riding. Obviously easier said then done.
YZF1000R Thunderace!
Wonder what happened to my old YZF, sadly likely in a scrap heap somewhere now. Loved that bike, still one of the most fun bikes I've had.
Bike cleaning
Buy some WD-40 Specialist Degreaser, it's citrus based so isn't an alkaline so won't damage the aluminium.
electric motorbikes
Hopefully it was just a near miss, everything ok?
electric motorbikes
I'd love to have a go with one, I can really see the benefit of commuting on one. I've been consiering changing my MT out for the last two years, have had enough of the whining triple noise. Sounds great when you're at high RPM around country twisties, but commuting to work my ears are crying. And yes I wear ear plugs. I'd love the quiet ride, BUT, I really feel the noise from motorbikes makes them safer. I still get people merge in to the side of me once a month, I'm on a loud bike, wear high-vis top, white helmet and try not to ride in blindspots and it still happens. I bet accident rates would skyrocket if everyone moved to electric bikes.
Hey all, it's finally happened! Yamaha recommends torquing the rear axle nut on the MT-09 to 108 lb-ft, which honestly seems pretty excessive. I’ve always stuck to 100 lb-ft using a proper calibrated torque wrench and I’ve still ended up with some thread wear on the axle and nut. I went to tighten the wheel and I had that horrid feeling of realising it turned to infinity. From what I’ve seen online over the years and now finally experienced myself, that high torque might be fine the first time with brand-new parts, but it’s not good if you’re adjusting your chain regularly. I think most of us are loosening and tightening the axle fairly often, and that kind of repetitive stress seems to slowly wear things down. I've learnt from this, as it's completely my own fault still, a 7 year old bike and I've never changed those parts. What I’m planning on doing now: Torquing to 95–100 lb-ft max, and that’s only if the threads are clean and in good shape. Swapping out the axle nut every once a year. If I use a bit of anti-seize, I will drop the torque a bit more maybe 90–95 lb-ft. So, when should you replace the Axle? I've researched this and can't find an actual recommendaion, I guess if the threads are still clean and not damaged, you can probably get years out of it, seems like 7 :) But if the nut doesn’t go on smoothly or you see any flattening, galling, or metal flecks… it’s probably time to bite the bullet and replace the axle. I’d now going to take it out and check it once a year. Curious to hear what others are doing with your bike, anyone using Loctite and going lower?
Australia wins the world's worst roundabout award
Subjective, but at least that one actually works.
Just seen this in my local news... luckily it's not near me. https://www.smh.com.au/national/nsw/is-this-sydney-s-worst-roundabout-drivers-perplexed-by-bizarre-new-intersection-20250627-p5mapt.html
