DirtyDT
Everything posted by DirtyDT
  1. Probably a bad connection so it is shorting or your regulator isn't working and the speedo is taking the full magneto power.
  2. I had a similar problem with the SV. I got a great one from German ebay for a song.
  3. Hi and welcome to the forum.
  4. Hi and welcome to the forum.
  5. Hi and welcome to the forum.
  6. DirtyDT replied to up.yours's topic in Classics
    As per drewpys answer. The weather (heat) can mess with the master cylinder seals if they are on their way out. Had it once on a car in baking weather. No brakes. Not good kev.
  7. Number 8 it is. Check that item 8 is not too loose. strip off item 15 It doesn't have to be really tight but and then you can get to item 8. You need a C spanner (people use a flat screwdriver and hammer but not recommended). Tighten up 8 until it is not stiff but not too loose. It squeezes the ball bearings which may have worn due to use or lack of grease. Personally I would change the head bearings. Taper ones are best if you can get them. if not, and you strip this down further, you will probably find that the ball bearings are in bad condition or even have some missing. Lots of grease around the ball bearings.
  8. I thought the video started off showing her after she had landed on her face.
  9. yep. At the top of the frame neck there should be a large threaded ring that is normally tightened by a C spanner. It tightens up the head bearings when they start to wear. You may have to remove the large stem bolt and a cover to see it. It will be at the top of the part of yolk (triple tree) that goes through the frame.
  10. DirtyDT replied to danzley0's topic in Yamaha Customs
    Hi Dan. How old is the battery? If it is too old it may not be holding a charge. If it is just "hit and his" it sounds like a bad connection somewhere. Clicking normally means a relay. I would check and clean all the earths and terminals from the battery to the relay and then to the starter motor.
  11. Does anyone know any Yams that would have a 6 7/8 or 7" headlight - trails type - same distance between the ears? I am looking for something that looks like a DT complete unit if they are 7 inches for the Suzi. UK spec or at least MOT'able, 6 volts with a pilot light. I am not asking for a shed raid, just something that I can get as a pattern part. There is some stuff on evilbay, but nothing grabs me. Thanking you all very much.
  12. Gave up my London commute 5 years ago after about 30 years of the same. What used to get me were the cyclists just cutting out and the pedestrians with HUGE headphones on, crossing without looking.
  13. +1 49? have they lost a decade somewhere Have a fab day Drewps!
  14. We are used to getting out of tight spots. Brake shoes - rough and then clean the inner drum as described. Be careful to use a fluid that evapoates and does not lubricate. Wobble - although the head bearings aren't "rough or catchy", do they need just pinching up a bit? Forks - the springs go but change the oil just in case. It can't hurt. It looks fab.
  15. Hi and welcome to the forum Baggo.
  16. DirtyDT replied to Cynic's topic in The Bar
    It's a great feeling Jason. It's when they start shouting "faster"
  17. "I assume that means connect the red wire from the switch to a +ive that is only live when the ignition is on? I am pretty sure that this is exactly what I had tried." Thats how I read the instructions. You should have a perm +ve to the battery, a perm -ve to the battery and then the red to the +, Try wiring up the perm + & - and the lights. temporary connect the red to the +ve of the battery to see if it works.
  18. Hi and welcome to the forum. It does look like the bike in the other thread. As for "what do do next", you can always put it in a crate and ship it to me
  19. Hi and welcome to the forum. You really need to post a decent "hello" here and then ask a question in one of the sections you can find at the bottom of the home page. That said, have you rejetted the carb?
  20. DirtyDT replied to BlackStar's topic in Yamaha Gallery
    Or a hosting package and FTP them.
  21. That can't be right. Blacks are -ve, white are +ve but you can't have a switch with one red wire on it! I have pulled up the instructions. red - feed from switched power all whites are +ve All blacks are -ve
  22. DirtyDT replied to tgsm7's topic in The Bar
    Good bikes , them.
  23. Do you have feelings of inadequacy ? Do you suffer from shyness ? Do you sometimes wish you were more assertive ? If you answered yes to any of these questions, ask your doctor or pharmacist about - Cabernet Sauvignon. Cabernet Sauvignon is the safe, natural way to feel better and more confident about yourself and your actions. It can help ease you out of your shyness and let you tell the world that you're ready and willing to do just about anything. You will notice the benefits of Cabernet Sauvignon almost immediately and, with a regimen of regular doses, you can overcome any obstacles that prevent you from living the life you want to live. Shyness and awkwardness will be a thing of the past - you will discover many talents you never knew you had. Stop hiding and start living. Cabernet Sauvignon may not be right for everyone. Women who are pregnant or nursing should not use it. However, women who wouldn't mind nursing or becoming pregnant are encouraged to try it. Side effects may include: dizziness, nausea, vomiting, incarceration, loss of motor control, loss of clothing, loss of money, loss of virginity, delusions of grandeur, table dancing, headache, dehydration, dry mouth, and a desire to sing Karaoke and play all-night rounds of Strip Poker, Truth Or Dare, and Naked Twister. WARNINGS: * The consumption of Cabernet Sauvignon may make you think you are whispering when you are not. * The consumption of Cabernet Sauvignon may cause you to tell your friends over and over again that you love them. * The consumption of Cabernet Sauvignon may cause you to think you can sing. * The consumption of Cabernet Sauvignon may create the illusion that you are tougher, smarter, faster and better looking than most people. Now - just imagine what you could achieve with a good Shiraz ! !
  24. Check the way you have wired the relay. The relay is just an automatic switch. 2 circuits. The bike live wire in and out and the higher powered cables to the lights in and out positive only, normally.
  25. DirtyDT replied to BlackStar's topic in Random
    I haven't see the forecast but it must be sunny all day; the road is full of Harley and power rangers today. Where we're they in January?
