Everything posted by drewpy
I think I might have brought my next project.
I got some aap Taiwanese rims from a company in NI £4 delivery look ok too http://motorcyclemegastore.com/motorcycle-wheel-rims
looks ok to me too. no where near as bad as the Gilera I started with. the front wheel spokes look new and the rims look good too. rusty wheels can take £400 off you easily
Jumping Sparks
try a new spark plug too, as it might be fouling up/insulation breaking down
Worth a Punt?
he says it needs a new engine! unless you have access/funds to get another engine I wouldn't bother at that price. If your really stuck on it, take a gamble and let it run. email the seller and get him to lower the price
ok socks and dogs = win
trust fail
and now it looks like this
fzr600r rear shock alternatives
shock alternative
What causes RPM to go up and down when idling?
good to hear
my throttle usually makes my revs go up and down seriously, its running a bit lean, the modern fuel now has ethanol (alcohol)in it which loves attracting water. tweaking the mix screw out to enrichen the air/fuel mix like dt50 said, on the xs400 its now 3 turns out. You may have to up the slow jet 1 step.
Hey y'all!
Haley, hows the comet?
Can I use the brake light switch from a Xs650 to my XS850?
I think they would be the same, most of the xs range from the same era used yam parts bins. usually if it looks the same, it is.
- Howdy Folks
- Forums
A Mans Corner...
I'm in Belgium with the scouts, mind you if that changes. I'd love to go
A Mans Corner...
the manx GP is looking good this year. With the new changes they'll be a few more pre 80's gp bikes
Snow Again !!!!!!!!!
no snow here. even went out for a chilly ride
And So It Begins,,,,, Mini Bike
nice one Pat, photobucket has been upgraded and just getting the img tags is a PITA and i've told them so
xs250 rebuild
follow this then... big end bearing housing #3 crank pin dia # 1 = blue big end bearing housing#4,crank pin # 2 =black big end bearing housing #5 crank pin no # = Brown big end bearing housing no# crank pin no # = Green
Manchester Motorcycle Show Sat 12th Sun 13th January
crap show last year. Michael Dunlop was there and no-one knew him. I'm going to the event city one in March
Classic vs Custom
that's a latre one, a "custom" bike. I do like the xs650 (prefer the XS1 version with drum brake meself)
Classic vs Custom
depends, does he like riding or fixing? the xs will be a great bike but will need fettling depending on condition etc the virago's will be more dependable (depending on condition) boils down to back lane scratching or cruising the highway/posing
Foamy is going "insert location" for a week
is that foams large cig?
FZR600R exhausts
cool bikes you had. As blackhat says, start the thread in workshop and you'll get a better response
xs250 rebuild
tell us what colour you got and i'll give you the info you need, ie part number
