drewpy
Everything posted by drewpy
  1. not been brilliant, its a bit like a nuclear winter, dull dull dull with acid rain evry now and then
  2. looks like you had a great time and you had the weather? wish it were better here!
  3. to the YOC hornix nice bike drewps
  4. drewpy replied to mervin's topic in Video Section
    brill, slick conversion
  5. to the forum jquinton
  6. looking good my friend, keep those cases polished
  7. you've got the unusual version. this is a swinging caliper and was fitted to the rd400 daytona model (us version) there is a thread on this very caliper somewhere. HERE
  8. drewpy replied to oldtimer's topic in The Bar
    I like the MT-03. don't forget i get 1st dibs on your FZ though
  9. Ritlow the needle position determines the midrange carburation. raising the needle richens and lower = weakens. I've checked my manuals and they don't say where the count is taken. looking at the pictures in there, the E-clip looks near the bottom part of the needle if that helps.
  10. you can't beat a bit of kinetic engineering
  11. sounds like the carbs need balancing. one pot is dragging the other, you sound well chuffed getting it going
  12. drewpy replied to Ficky's topic in Yamaha Gallery
    looks a modern enfield, and you had to rebuild it? those LC wheels, or are they standard in OZ?
  13. welcome back foams, you keeping mistress goff captive down there?
  14. the easiest wsay to check your at TDC is put your thumb over the spark hole and listen for compression. Thats' turning the crank anti-clockwise on the left hand side the LT nearest that compression stroke is the one you use. LF is the firing mark and is in advance of TDC as it takes a millisencond for the fuel to ignite and the flame front to expand and send the piston down.
  15. I grounded mine, but looking at the schematic, looks like they don't need to be!
  16. there were 2 different types of caliper used in the xs400. 1 was a floating caliper design (common) and the other used a sliding pin design. let me know which one you have! (or post a pikkie)
  17. crossed me legs in some places
  18. you can get cam chains with a soft rivet connection, i personally would split the cases and do it properly bike looking great
  19. drewpy replied to mervin's topic in The Bar
    memories for me too merv, good pikkies
  20. drewpy replied to mervin's topic in The Bar
    O. M. G.
  21. I go away for a week and this happens
  22. you would have to open the left case and stator off ( a pig of a job) and replace the stator case, buy a motor and wire it in. I personally wouldn't bother, there was only a couple of models which were kick only anyways, i think they ended in E as econony model and usually had wire wheels ( well sort after part now)
  23. drewpy replied to drewpy's topic in The Bar
    this is the initial one i did. the only proviso that the badge makers said was they can't do the graduations or 3d. if anyone has a better design, go ahead and we could have a selection process. I'm off for 1 week now so we could end entries after then!
  24. drewpy replied to ReBorne's topic in Yamabyss
    when i was a butcher, we used to say "good morning" to the fridge. without that fridge we wouldn't have a job, never broke on us in 2 years
  25. my mate bought the xj6 coz ha had a 0' finance deal. cracking bike and a looker (has no fairing)
