drewpy
Everything posted by drewpy
  1. drewpy replied to drewpy's topic in Projects
    ..still waiting for parts
  2. drewpy replied to drewpy's topic in Projects
    and time to make brews
  3. bring back a burger then
  4. I think its a given, love it in there
  5. we'll meet at maccy D's again leaving at 9am
  6. smile, your on camera
  7. drewpy replied to drewpy's topic in Projects
    we have bike shops, but don't stock everything especially non-resistor spark plugs
  8. z400, what a dog that was!
  9. drewpy replied to drewpy's topic in Projects
    thanks felix, i have an fz engine in the shed. just ordered some non resister plugs as maybe the dynas have resister silicone leads. ordered some oil for opie too
  10. nope! to keep the forum going, it needs money
  11. drewpy replied to drewpy's topic in Projects
    I'll check it Tommy, but there's only the loom in the upper frame that's original.No chance of any oil soaked wires there.
  12. nah, riding comes first! so long as the weather is ok (and its supposed to be)
  13. for the gilera tank I used vinegar, worked a treat. Watch alloy though, it eats it
  14. drewpy replied to drewpy's topic in Projects
    wouldn't rec over 1200, no airfilter on and no exhaust too it was loud! might go with the non -resistor plugs, maybe the silicone leads are resistor leads!
  15. we tend to find that peeps who do an intro first and then ask q's later tend to stick around and helping those peeps out tends to feed other posts which keep the forum alive. someone posting a question as first post only gets peoples back up as, happens all the time, we never see them again and we feel used because of this. Hence DT's post
  16. drewpy replied to drewpy's topic in Projects
    well this is strange, wired in the new pickup coil and it didn't spark again. shortened the lead and it sparked! got continuity in the loom, so maybe its the ohm thing. got the engine going, but wouldn't rev at all, pulled the carbs but they were clean (from the last job) I do have another pickup but its 290 ohm with 1.5acv as opposed to 98ohm with .8 acv any thoughts on using that one?
  17. I always like to clean the engine before I strip it, bolts etc get stick on the grease and get lost. did you put some oil down the bores or was that already there on the stripdown? you don't want smoothbores but a nice 45' cross hatch hone for oil retention
  18. drewpy replied to drewpy's topic in Projects
    found me spark; combination of things 1) couldn't get to fire manually off battery, so took off the caps and the spark was very weak. even though Dyna say it doesn't matter which way the connections went,I turned them round and got a better spark. 2) kept the 5k caps on and resistor plugs as both = 10k ohms which is correct for the bike 3) tried an R1 pickup/trigger coil and it gave our 1.5volts, 3 times the old one. this told me that the one I have must be faulty 4) there was some rust/paint on the raised parts of the mag, so cleaned them up with wet and dry 5)installed a new trigger coil and got spit back out of carbs, so got sparks. still need to wire it in properly, but its had quite a downpour today so hopefully will get out tomorrow and see what's what she's not running as yet, but at least I'm getting there
  19. FFS
    drewpy replied to jimmy's topic in Yamabyss
    I got irons from Stafford s few years ago, £10 for 2 paid for them selves a couple of times as helped a few peeps out changing their tyres
  20. unfortunately its worth about £800 to £1k tops there just isn't the love out there for them.
  21. if the gear moves, its worn. I had to drill the hole larger to accept the pin and drive it in. being spilt it will deform to fill in the wear.
  22. please read my post above re:pins
  23. Can't wait to see your handle bar videos in different countries
  24. drewpy replied to drewpy's topic in Projects
    ok I managed to get a spark from the dynas off the bike taking out the 5kohm cap and resistor spark plugs and using a nail instead I've earthed the TCI in the right places to the frame and confirmed its earthed. basically the TCI is a posh earth switch controlled by a chip to change the frequency of the switching.
  25. yay, well done
