Everything posted by drewpy
New to the group
aboard post your Q in the classic or workshop section
Fz600 Gulf
Just done my cam cover in VHT crinkle finish looks the dogs B
Yard Built dealer contest
Yamaha have set-up a Yard Built dealer contest to promote a bit of healthy competition in their network. Best bit is, many of the parts developed and used on these bikes will soon be available over the counter.
XS250 Kickstart jam?
did you try to pushjovert the kickstart with the clutch engaged so it eliminates the valve train as I suggested earlier?
have you double checked valve timing? it can be easily 180' out
Mobius cam
Hey Guys, Just bought a Mobius cam from Banggood UK warehouse. http://eu.banggood.com/Wholesale-Warehouse-Mobius-New-Version-Wide-Angle-Lens-C-1080P-HD-Mini-Action-Camera-wp-Uk-966178.html got it for £50 and is a cracking little action cam. just ordered a waterproof cover and a mount which goes on the rear mirror stem from Joovuu (stockport based) https://www.joovuu.com/gb/mounts/159-motorbike-mirror-mount.html?search_query=mirror+mount&results=1 .loads of parts available dead cheap and loads of accessories too. when it comes I'll review it and obviously take some footage (maybe sunday going to the show)
- FJ1200
Younggun from Finland!
Kashmire
Chicken shed find
you'll need AC bulbs as LED 's only work in DC mode. just saw a film about Tesla, very interesting
- Chicken shed find
FJR SAGA!
never mind, just think about this time next year when its all in the past I'm still waiting for my rear shock to be finished. They are having issues taking out the bushing due to it being there for a few years and a 40 ton press won't shift it! can't do anything else till the shocks fitted
ouch! may be try it with the clutch in, it won't kick over the bike but just spin the clutch basket. just in case the top was not timed properly
- XJ900F - getting a new home
remember back when.... 1990
shouldn't watch it whilst doing the dishes Kev
only better when the kids are off school, tells you something about today's parents. I hardly ever took mine to school, they walked or took the bus
hard to tell via text, sounds about right what you say. maybe try and do it again, you don't need to drain out the oil, keep the bike on its side stand and the oil will drain to the left. (thats why I start the bike upright so the oil pump gets some oil to pump) just don't try and kick over without the cover on as it will snap the crankcase bearing in the gearbox and will scrap the cases.
is the side cover fitted? I always have issues getting the kick stop and gears to mesh when putting in the kick shaft. Its usually trial and error for me and I've rebuilt 3 engines
Amazing vintage bike
geeze, shit happens man. good opportunity to buy some new stuff
xj600 running on 2 cylinders
yep, CDI went out early 70's could be either the ignition caps or leads if you can get 1 and 4 to work
do you have a spare TCI?
Classic TT
schedule is now out http://www.iomtt.com/Classic-TT/Classic-TT-Schedule.aspx
therm shock will get them off as Slice suggested, heat,then cold ad infinitumn. should come loose eventually
these have one pickup coil. its a wasted spark system so 1 and 4 cyl sparks and so does 2 and 3 so I'd look at the coil. First look to see if 12v is reaching the coils with the ignition on. The TCI earths to ground to complete the circuit, also check the HT caps as they fail too. I assume you've swapped the plugs in case they are faulty?
it depends on which year is your xj, the '91 has one pickup coil, earlier ones had 2.
Lotherton Hall Cancelled
my mate was part of the Lymn show, I did the older venues, but never went to the Barn Owl (I might shut it down like the others) RC31? nice
