Everything posted by Twin Shock
DT100 Carburetor
What year model is your DT 100.
1975 DT 400
Completely disassmeble the carburator and clean,and then clean somemore. I don't know if you have "Berryman" parts cleaner where you are but it does a great job on removeing dirt and varnish deposits. Replace "ALL" the rubber "0" rings and seals and re assemble. Hopefully you don't have a problem with the CDI but take care of the carb first. Also make sure the airfilter is not dry rotted and your sucking it into the carb.
Anybody have any experiance with 1976 RS100?
Sounds like it is still not getting fuel, did you turn the petcock to the off position. Pull the gas line going to the carburator and make sure you have fuel reaching the carb.
Yamaha will still carry some parts for the bike, then there is E Bay.Speed and Sport also carries alot of NOS Yamaha parts. Sounds like you need a new ingnition switch for your lights to switch on. Someone must have unplugged the switch for the engine to run.
250 or 450
I have a WR 250 R and really like it. The WR 450 is not street legal in the USA.
1973 DT175
First of all we need to ID your bike. If it is a 1973 you have a CT3, They changed to the DT in 1974. In the US the CT was gold and the DT was blue. Do you have a picture.
what bhp is a 2002 wr250
I agree,that does sound low. Just posting numbers I found.
I have seen claims from 15 to 28 claimed HP.
air cooled yamaha dt 125 poor running
Lee, I would go back the the carburator and replace the "O" Ring on the Neddle jet (main nozzle) this little "O" Ring is very important and must be in good condition. The bike will not rev if the "O" RING is not sealing. This is a easy start to finding your problem.
1974 TX500A, need advice/wisdom
Motorcyclecarbs.com has the kit.
Replace the air filter to the carburators, If the tank has been sealed install inline fuel filters, change the engine oil. If the oil seals have not dryed out you should be ok. After you get the engine running have the valves checked, or before.
DT250 rear shocks
Progressive makes shocks for the bike and there are thermal flow shocks just like on your bike on E Bay all the time.
I need to know the year model of your bike and I can help you.
Need help for my 14 yo just bought 1970 80cc Enduro
If the autolube system has been removed you should mix at 32 to 1 ratio.
- Another Addition to my Stable.
Fast Bike.- 1977 DT250 photos
Guys, check out Yamahaenduro.com The September bike of the month is a 1979 DT250 for your pictures and anything esle you need can be found there.- 1976 yz125c aircooled engine help
The 1982 YZ 250 in the US was liquid cooled. Any air cooled model YZ, IT engines have differences as they were designed for different purposes. They will interchange frame to frame from the same year if that is what your looking for.- yamaha it250 engine the same as yz250?
I can on reply for the US MODEL. The engines are totally different. The YZ in 1982 was watercooled. The transmissins ratio's were wider in all IT's- Yamaha sr125 Chain and sprocket help needed
You chain and sprockets are completely worn out, I would not ride the bike until they are replaced.- 1973 Yamaha AT3 wiring help
I can only speak of the US models.- 1975 DT 125 b sprocket
The standard sprockets were 14 T on the counter shaft and 45 T on the rear wheel.- 1973 Yamaha AT3 wiring help
If you really want to do this I would suggest you buy a parts bike and use the wiring harness, voltage regulator,ingnition coil,stop switch ect....... and you must have a 12 volt battery for this engine to even run. The at series enduro's are 12volt to power the electric starter.- 1973 Yamaha AT3 wiring help
- 1970 DT1C restoration question
Mark, you need to join Yamahaenduro.com There are absolute experts there on you particular bike and more. - Another Addition to my Stable.
