one2dmax
YOC Member
Everything posted by one2dmax
  1. How much rebuilding are you doing? You can either take the engine cases in and get them soda plasted or even dry ice blasted. Both medias are excellent for almost all metals and even softer materials. It will look like new and even a bit polished if you use the soda blasting. You can also use that for the valves. I have used a fine wire brush and general solvents (spray can carb and even brake cleaners) to remove the heavier deposits. Sean Morley
  2. one2dmax replied to prettyboyr12002's post in a topic in Naked
    It sound like the gears engagement dogs are rounding off which is very common on many transmissions (especially 2nd gear) I can get the trans undercut at Fast By Gast for you (they are undercut a little from the factory). They do excellent work and I am setup with them. I have had numerous transmissions done by them and all shift better then new when I get them back. You'll want to check and probably replace the shift forks while you're in there. Also, look the drum over carefully as they wear too. Typical price runs between $350-$500 depending on how bad the trans is. They can generally hard weld any heavily worn dogs and re-cut them. It's cheaper then a new gear would be but just as strong (or stronger). Sean
  3. one2dmax replied to gavi_omen's post in a topic in Naked
    I've had my 83 Seca Turbo since 88. It survived a major accident (woman ran a red light and I caught her in the act!). Since that time I have had 4 750 maxim engines in it (2nd gear always fails and another engine is cheaper then rebuilding one). I currently am in the process of getting it back on the road (haven't ridden it since 94). This winter it is getting a 900 engine installed! Sean
  4. one2dmax replied to Mayharg's post in a topic in The Bar
    I've got a couple of friends with those bikes and they love them. I am sure you would be very happy with one too. Sean
  5. one2dmax replied to Goff's post in a topic in Yamaha Customs
    If you don't have any luck you can email me direct with what you need. I am setup as a dealer for them but don't order much. [email protected] - shipping still is expensive but not that much. Sean
  6. one2dmax replied to wil6488's post in a topic in Naked
    I forgot to mention. I may have spare parts for that bike laying around too. I have two FZ600 chassis's in various condition. I won't be the cheapest you can find but won't misrepresent anything either. Sean
  7. one2dmax replied to wil6488's post in a topic in Naked
    Normally the sidestand switch is routed up and rearward to a 2 wire plug in but yours is a bit different. From the looks of the microfiche (http://www.starmotorcycles.com/star/parts/home.aspx) it looks like you have the switch with it's two wires going into an extension harness (all routed forward) which in turn plugs in to the main harness. If you can find the main harness connection point you can jumped the terminals to bypass the switch for now. Then you can order the part you need to fix it and get it back to normal. Sean
  8. one2dmax replied to rdyam1's post in a topic in Yamaha Workshop
    Best bet on these questions is to ask the guys on the XJBikes.com website. Sean
  9. one2dmax replied to wil6488's post in a topic in Naked
    Sounds like the sidestand switch is sticking. It's mean to kill the bike if the sidestand is down and you put the bike in gear. If you put it back in neutral and it starts then that's where you need to look first. If you get the sidestand working and then it runs once started and put in gear but won't start with it already in gear and the clutch pulled in then the clutch switch is bad (located on the bottom of the master cylinder). You may have both issues so tackle each one separately starting with the sidestand. Sean
  10. one2dmax replied to a post in a topic in Naked
    I do know the R1 calipers and R6 are the same and will work for most swaps well. BUT, the 04 and up are radial mounted and will NOT swap. Sean
  11. one2dmax replied to lukey's post in a topic in Naked
    "Honda Polish" - best I have ever found! Sean
  12. one2dmax replied to a post in a topic in General
    Update - I wasn't using tap water (sorry - was using distilled). It worked ok for the rubber based parts like the slides and small stuff and only marginally worked on the rest of the stuff. Swapped out the water for my cleaner and what a difference. I had left the cleaner on all night and it only took 30 minutes for the HD cleaner solution to work! Sean
  13. one2dmax replied to a post in a topic in General
    I am trying plain tap water on this current set of carbs. It's been in overnight this time since it wasn't ready in the three hours I was at the shop yesterday. I have also heard that good results can be had by putting the carbs in an old pan or pot and boiling it in distilled water on the grill then using a dental waterpick to clean the orifices out with. Sean
  14. one2dmax replied to Chicken's post in a topic in Classics
    Might want to check your contacts to see if there is any corrosion. It may be as simple as replacing one or more of the bulbs. Sean
  15. one2dmax replied to paul123's post in a topic in Yamaha Workshop
    Thats the simple and inexpensive way to get the job done but a pin could always work loose and create some damage. You could weld the drum too. I imagine we could make a 2 speed transmission but it would be a lot easier to simply weld that drum up. You can possibly also remove the shift segment pins from the end of the drum assembly. I don't remember if it's accessible from under the clutch basket but if it is you wouldn't even need to remove the engine from the chassis. Just pull the end off the shift drum that the shift shaft engages and just remove the unneeded pins so it won't shift for those gears. Sean Morley
  16. one2dmax replied to BobVal0's post in a topic in Yamaha Workshop
    You can buy the "tamper proof" torx bit for them but I just use vicegrips (carefull not to grab too deep as it will scar the cover a little). Just crack them loose and you can remove them by hand 95% of the time. Sean Morley
  17. one2dmax replied to schulz476's post in a topic in Classics
    Agreed. That 850 should smoke it. Sean
  18. one2dmax replied to BobVal0's post in a topic in Yamaha Workshop
    I do them regularly (4 sets last month) and I have never had a bolt break. They are almost always stuck. You can use vicegrips too which works well. They will only be tight right at the start then will pop loose and come out very easily. If you think you may be servicing in the future (or tuning for a jet kit) then you may want to buy new allen headed screws from your hardware store and replace the screws. I specialize in Vmax stuff and keep a lot of parts (new and used as well as custom/modified) on hand so feel free to ask any questions you like and i'll help if I can. Sean [email protected]
  19. one2dmax replied to BobVal0's post in a topic in Yamaha Workshop
    Are you talking about the screws in the carb diaphram covers? Those screws like any of the other ones in those carbs are easily broken loose with an impact screwdriver. I whack it a few times in the center position of the tool them turn it to the loosen position and one whack has them loose. You may want to join the vmaxforum.net site and check as there is detailed pics of the carb removal and also another section that shows how to set the float height correctly on the bench. Sean Morley
  20. one2dmax replied to cb500t's post in a topic in Yamaha Workshop
    Not sure what the bolt spacing is but I believe the older vmax was just under 290 while the newer ones (and r1's) used 298mm rotors with 6 bolt spacing. Sean Morley
  21. one2dmax replied to Brady's post in a topic in Yamaha Gallery
    I've been having friends buy radians or FZX/Fazers for starter bikes. They are getting very hard to find for either one. Both are light and nimble and of course the FZX is much faster. The radian is still a very good bike and dependable too. Good luck making it your own! Sean
  22. one2dmax replied to martinfan30's post in a topic in Classics
    You'll probably get some good answers here but you might want to try XJBikes.com as well. Sean
  23. That's what it sounds like to me. Look at the bottom of the waterpump. Look for the "weep" hole and see if there are tracks from the coolant leaking out of there. Sean
  24. one2dmax replied to carter8838's post in a topic in The Bar
    I sell sprockets from Sprocket Specialists. They have always made anything I was looking for. You can either buy them direct or send me an email and I will check to see what I can get for you. Shipping overseas will add a good deal to the cost though. Sean
  25. one2dmax replied to socalyamaha's post in a topic in Classics
    They do look a little different but I would need to really get up close to one to see. If you look at these pics: http://bikepics.com/pictures/1225566/ http://bikepics.com/pictures/1202775/ they look pretty similar but from the other side they look even more different. There's a 550 engine on ebay right now for around $200 I think. Shipping overseas isn't impossible but it does make it a lore more tricky. Sean Morley
