fz1s fazer abs scoit oiler fitting
fz1smith
This post is 6168 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
i just bought a new 2007 fazer 1000 and i have bought a scot oiler.
The web site shows a nice picture of the pipe that i need to connect the vacuum t piece into.
trouble is that i cannot find a pipe that looks like this.
Do i need to take a panel off or remove the tank?
I dont't want to go removing stuff just to look for this vacuum pipe, so and more specific instructions would be appreciated.
Thanks in advance,
Peter
PS the 2007 fazer is fixed, the throttle response is loads better than the 2006 model i tested.
All the vacuum hoses are likely to be on top or around the injectors and other parts of the engine, which means it's a tank and airbox off jobby. Shouldn't be too much of an issue as most bikes have similar ways of keeping them in place.
Regards
