2006 R6 Airbox Restrictor Plate
The Dude
This post is 6182 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
Alreet folks. I've heard a few reports lately sayin that there's a restrictor plate of some kind in the 06/07 R6. Anyone know anything about this and if it's worth removing if it is there? Cheers
It is true it is just a plate on the bottom of the air filter. If you take it out of the air box all you have to do is pop off the rivets and the plate will come apart. Apparently its a non reversible mod though.
Regards
Depends because some of them come with the restrictor plate as well. If you can see what looks like an oval on the bottom of the air filter it is on still. Basically the filter should look the same shape and size both top and bottom.
Regards
