YZF750R 6-speed Transmission
jlabrie
This post is 403 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
Greetings. I hope someone out there can assist. Does anyone have the gear ratios for the YZF750R 6-speed transmission?
I actually have two YZF1000R engines, one with the standard 5-speed, the other with the 6-speed from the YZF750R.
While I'm looking for the ratios for all gears, the final gear (6th) is the most important as I am trying to calculate top speed when using different gearing combinations on the rear end, and without the gear ratio data I am stuck.
Thanks very much in advance for the assist.
John
  • Admin
I will try and remember to get these for you first thing in the morning B)
  • Admin
YZF750R Gear Ratios
Gear Ratios (no. of teeth)
Primary Reduction 1.896 to 1 (91/48T)
Final Reduction 2.688 to 1 (43/16T)
1st 2.571 to 1 (36/14T)
2nd 1.941 to 1 (33/17T)
3rd 1.556 to 1 (28/18T)
4th 1.368 to 1 (26/19T)
5th 1.217 to 1 (28/23T)
6th 1.083 to 1 (26/24T)
Shaft runout (max) 0.08mm
  • 16 years later...
Here's a piece of thread necromancy...
So, to add to this thread, I have a different question:
1/ Is the 750s 6 speed gearing strong enough to handle the 1000r?
2/ Bearing in mind that the above numbers supplied by Alex mean ABSOLUTELY NOTHING to me, how does the 6 speed box compare to the 5 in the lower gears? Does it gain or lose acceleration (because let's face it, acceleration is what the Ace is all about!)?
