H4 Headlight
padstow2004
This post is 6469 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
Hi I Have A 1981 XS400SE is it possible to convert the headlight To the more powerfull H4 headlight
I belive a honda superdream 250N lamp fits, never tried it myself though and i would consider reducing the rear lamps to 8 watts or so to compensate for the voltage drain or you may find that the charging system can't cope. (halogen 60/55 W) you may need to fit the H4 connector as well.
if you want to have the proper reflector then try
http://www.pgmyamaha.com/MOCOMMAINLIST%201.xls they have a kit for the RD's which should fit the XS, I would phone first as they are very helpful.
I bought a gear change shaft marked for a rd400 and it fitted my XS (you can't get these from yam any more)
Yes the Honda wet dream one dos the trick i have one on my Rd400 and another nos stock one to go in my next project 400, or as you say Jonny at PGM is a very helpful guy and has the halogen units,
Merv
