Stator testing
Variomatic
This post is 2550 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
I need to know how to test a stator, the better on my bike isn't charging and am suspect theirs no output, or very little from the stator, and for the first time in two years my Haynes manual has let me down and left me confused.
It has 3 outputwires, all white, anyone have any ideas as to how to test the windings? Do I look for continuity? Or measure the resistance? Is their a sequence to testingor do I just pick any two random wires outf the three?
Any help at all would be appreciated :)
Measure resistance between them all, you should get 3 identical readings. Also check each one for continuity down to earth (frame).
Alternatively with the bike running you should get an AC voltage on each.
Yeah that does seem low. What are the resistances like between the windings and the frame or engine casing?
Resistance between the windings seems to be 1-1.2 Ohms, which seems way, way to low to be, as far as I knew that should be closer to 50-65Ohms (I'll have a look in my Manual later to see if it says.
Since when it revs up it puts out 12.5V (still anemic) it's JUST about enough to keep the battery charged and barely running, but you can tell it's not happy. I really don't wanna have to replace the stator, it's an oddly expensive part for the EFI model but I might have too
You need to test the output from the stator though, if that's good then it will be the reg/rec or possibly the cabling in between the two
