Dragstar 650 - Engine management light
Finch127
This post is 3314 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
Hey,
I have a 2005 Dragstar 650 with 28k miles on her.
Recently the speedo cable broke on me and when I drove it, and tried to redline it , the engine management light would come on and a rev limiter would kick in , like the bike was choking itself , there was 3 flashes of the engine management light when the kill switch was hit
So I replaced the speedo cable thinking it was that causing the issue but its still happening :S
Now there is 4 flashes of the engine management light instead
What has changed since before this happened:
*Engine oil change
*HID kit installed ( No wires modified to do this - its plug & play)
*Basic alarm installed (Only two wires to the battery - no wires modified)
*Speedo cable broken
What i've tried so far:
*Speedo cable replaced
*Disconnecting the the loom and the alarm/HID kit from the battery overnight
*Tested the resistance of the TPS sensor which is reading at just over 6ohms
Anybody ever come across this ?
update on this:
When driving at 50mph in 5th, if I pull the clutch lever in, and pin the throttle its fine, no management light is thrown up and it revs freely
When i release the clutch and pin the throttle and the revs climb , the light comes on and the revs limit :S
Aye finch " there must be a sensor fault, youl need to get it plugged in to a diagnostic lappy, to clear the fault ,or renew the sensor,
Might be unrelated but did you replace the speedo cable with OEM or some cheapie alternative? Word of advice: use the OEM cable, as the cheapies are not quite the right length they should be.
Yeah , Ill have to bring it into a local dealer at this stage , hopefully it isnt the CDI unit, they cost quiet a bit, maybe just the TPS
Used an alternative speedo cable , was the exact same length as I still had the old one thrown on the garage floor and compared them
When I used the alternative, it kept coming loose at the bottom. Never figured out why. Then I bit the bullet, got the OEM one and no probs since.
  • 3 weeks later...
FYI
Fixed it thank god
Noticed that there was a slight nick in the positive wire coming from the loom , that connects to the rear cylinders ignition coil
Wrapped it up and the massive 40bhp has been restored :)
