o5otato5o Posted July 14, 2014 Author Share Posted July 14, 2014 yes andrew now used tho lol think the soot is from when i put oil in the head as id been told previously but in tappets at min Link to comment Share on other sites More sharing options...
o5otato5o Posted July 14, 2014 Author Share Posted July 14, 2014 found it on here via a google Valve clearanceinlet 0.05-0.09mmexhaust 0.15-0.19mm Link to comment Share on other sites More sharing options...
AndrewElvisFan Posted July 14, 2014 Share Posted July 14, 2014 When you bump her and have her going, does she rev ok? I've been assuming that when warm she doesn't idle but ok when running along? Link to comment Share on other sites More sharing options...
o5otato5o Posted July 14, 2014 Author Share Posted July 14, 2014 no wont idle i have to blip revs Link to comment Share on other sites More sharing options...
Moderator DirtyDT Posted July 14, 2014 Moderator Share Posted July 14, 2014 Important bits in red. On the left hand side (nearside) of the engine there will be 2 slotted caps on the crankcase. You need to unscrew the top one to see the timing marks for tappet adjustment, the lower one to turn the crank and look through the top hole until you see the marks. Remember to turn anticlockwise. Rotate the crankshaft anticlockwise to align the slit on the rotor with the stationary pointer on the crankcase cover. When the piston is Top Dead Center (TDC) Measure the valve clearance by using a feeler gauge. Exhaust tappet is the one to the front of the bike near the exhaust. Tappets (measured cold): IN 0.05 _ 0.09 mm NOTE Millimeters not inches so check your feelers EX 0.11 _ 0.15 mm NOTE Millimeters not inches so check your feelers Spark plug: NGK DR8EA 0.6 _ 0.7 mm Carburetor: Type Y24P I.D. mark4WP-10 Main jet (M.J) #102 Main air jet (M.A.J) ø1.3 Jet needle (J.N) 4C9A-3/5 Needle jet (N.J) 2.600 Cut away (C.A) 2.25 Pilot outlet (P.O) 0.8 Pilot jet (P.J) #38 Bypass 1 (B.P.1) 1.0 Pilot screw (P.S) 2 Valve seat size (V.S) ø2.0 Starter jet 1 (G.S.1) #60 Starter jet 2 (G.S.2) #64 Float height (F.H) 28.5 mm Engine idle speed1,250 to 1,350 r/min Ignition timing: Ignition timing (B.T.D.C.) 9 degrees at 1,300 r/min Link to comment Share on other sites More sharing options...
o5otato5o Posted July 14, 2014 Author Share Posted July 14, 2014 right tappets set no change andrew can you get me a photo of your tdc marks lined up at all ? Link to comment Share on other sites More sharing options...
o5otato5o Posted July 14, 2014 Author Share Posted July 14, 2014 think timeings out ? how do i adjust it Link to comment Share on other sites More sharing options...
Moderator DirtyDT Posted July 14, 2014 Moderator Share Posted July 14, 2014 Link to comment Share on other sites More sharing options...
jimmy Posted July 14, 2014 Share Posted July 14, 2014 When you crank it over with the plug out and touching the cylinder head, is the spark a big fat blue one or a weak yellow one. I'll go down the route of the CDI (don't I always) and this is because my boys SR displayed the same symptoms. Wouldn't start on the button, but would bump start and run like shit Link to comment Share on other sites More sharing options...
AndrewElvisFan Posted July 14, 2014 Share Posted July 14, 2014 Sorry, can't get to my tools in the shed right now, but looks ok to me. If she runs when blipping, says to me it's the air screw. I could be wrong, but mine was showing similar symptoms before I got the screw right. When you bump start it, you're already taking it off idle the minute the engine starts. How old is your SR and how many miles has it done? Link to comment Share on other sites More sharing options...
o5otato5o Posted July 14, 2014 Author Share Posted July 14, 2014 Its annl reg so 20 ish i thinkand done 26700+ matching vin an engine aswel Link to comment Share on other sites More sharing options...
blackhat250 Posted July 14, 2014 Share Posted July 14, 2014 Sounds like low on compression,, starts cold- not when hot... = valves burnt or worn rings,, Link to comment Share on other sites More sharing options...
Moderator DirtyDT Posted July 15, 2014 Moderator Share Posted July 15, 2014 Sounds like low on compression,, starts cold- not when hot... = valves burnt or worn rings,, Very possible John but someone has messed with the tappets - which may show the same symptoms - so that is easy to correct. 1 Link to comment Share on other sites More sharing options...
o5otato5o Posted July 15, 2014 Author Share Posted July 15, 2014 So far been a nightmare im thinking ring/valve getting a nip backfire now i set valvs too tight? Link to comment Share on other sites More sharing options...
o5otato5o Posted July 15, 2014 Author Share Posted July 15, 2014 It lives but its now.loud it was my exhaust tappet because id set it.myself.it was too tight got a freind to hold stem (adjuster) while.i tighted nut she fires but tappets are now very loud altho for some reason.lots of oil missing but no.leak anywhere?? Link to comment Share on other sites More sharing options...
blackhat250 Posted July 15, 2014 Share Posted July 15, 2014 burning oil you mean,, ,,how often are you checking level,,,doe she smoke,,,, Link to comment Share on other sites More sharing options...
o5otato5o Posted July 15, 2014 Author Share Posted July 15, 2014 No oils.fine checking it warm.like a tit she had an oil.change a few days ago i havnt had her long Please not guys ur cam chain yensioner needs setting if it sounds.like.ur tappets are loud SHES ALIVE!!!! 1 Link to comment Share on other sites More sharing options...
o5otato5o Posted July 15, 2014 Author Share Posted July 15, 2014 Get you a.photo shortly lads Link to comment Share on other sites More sharing options...
o5otato5o Posted July 15, 2014 Author Share Posted July 15, 2014 Thanknyou all sooo much for sticking with me.and helping me.out 1 Link to comment Share on other sites More sharing options...
blackhat250 Posted July 15, 2014 Share Posted July 15, 2014 altho for some reason.lots of oil missing but no.leak anywhere?? What did that mean then,,,, Link to comment Share on other sites More sharing options...
