yes andrew now used tho lol think the soot is from when i put oil in the head as id been told previously but in tappets at min
  • Replies 87
  • Views 12.2k
  • o5otato5o
    o5otato5o
    What a diffrence that has made runs rides accelerates alot better best its run thankyou all be better on fuel aswell even tho it only cost a tenner every week or 2 lol
  • AndrewElvisFan
    AndrewElvisFan
    Welcome to the forum! It's normal to say hi in the new members section first - introduce yourself etc - you'll get a lot more help! That said, probably needs a new battery.
  • blackhat250
    blackhat250
    Rectifier/regulator, you need to check whats coming in [ volts] multi meter needed.
found it on here via a google
Valve clearance
inlet 0.05-0.09mm
exhaust 0.15-0.19mm
When you bump her and have her going, does she rev ok? I've been assuming that when warm she doesn't idle but ok when running along?
no wont idle i have to blip revs
Important bits in red.
On the left hand side (nearside) of the engine there will be 2 slotted caps on the crankcase. You need to unscrew the top one to see the timing marks for tappet adjustment, the lower one to turn the crank and look through the top hole until you see the marks. Remember to turn anticlockwise.
Rotate the crankshaft anticlockwise to align the slit on the rotor with the stationary pointer on the crankcase cover. When the piston is Top Dead Center (TDC) Measure the valve clearance by using a feeler gauge.
Exhaust tappet is the one to the front of the bike near the exhaust.
Tappets (measured cold):
IN 0.05 _ 0.09 mm NOTE Millimeters not inches so check your feelers
EX 0.11 _ 0.15 mm NOTE Millimeters not inches so check your feelers
Spark plug:
NGK DR8EA 0.6 _ 0.7 mm
Carburetor:
Type Y24P
I.D. mark4WP-10
Main jet (M.J) #102
Main air jet (M.A.J) ø1.3
Jet needle (J.N) 4C9A-3/5
Needle jet (N.J) 2.600
Cut away (C.A) 2.25
Pilot outlet (P.O) 0.8
Pilot jet (P.J) #38
Bypass 1 (B.P.1) 1.0
Pilot screw (P.S) 2
Valve seat size (V.S) ø2.0
Starter jet 1 (G.S.1) #60
Starter jet 2 (G.S.2) #64
Float height (F.H) 28.5 mm
Engine idle speed1,250 to 1,350 r/min
Ignition timing:
Ignition timing (B.T.D.C.) 9 degrees at 1,300 r/min
right tappets set no change andrew can you get me a photo of your tdc marks lined up at all ?
DSC_0146_1.jpg?noCache=1405368284
DSC_0148_1.jpg?noCache=1405368374125
think timeings out ?
how do i adjust it
When you crank it over with the plug out and touching the cylinder head, is the spark a big fat blue one or a weak yellow one. I'll go down the route of the CDI (don't I always) and this is because my boys SR displayed the same symptoms. Wouldn't start on the button, but would bump start and run like shit
Sorry, can't get to my tools in the shed right now, but looks ok to me. If she runs when blipping, says to me it's the air screw. I could be wrong, but mine was showing similar symptoms before I got the screw right. When you bump start it, you're already taking it off idle the minute the engine starts. How old is your SR and how many miles has it done?
Its annl reg so 20 ish i thinkand done 26700+ matching vin an engine aswel
Sounds like low on compression,, :eusa_think: starts cold- not when hot... = valves burnt or worn rings,,
Very possible John but someone has messed with the tappets - which may show the same symptoms - so that is easy to correct.
So far been a nightmare im thinking ring/valve getting a nip backfire now i set valvs too tight?
It lives but its now.loud it was my exhaust tappet because id set it.myself.it was too tight got a freind to hold stem (adjuster) while.i tighted nut she fires but tappets are now very loud altho for some reason.lots of oil missing but no.leak anywhere??
burning oil you mean,, :eusa_think: ,,how often are you checking level,,,doe she smoke,,,,
No oils.fine checking it warm.like a tit she had an oil.change a few days ago i havnt had her long
Please not guys ur cam chain yensioner needs setting if it sounds.like.ur tappets are loud
SHES ALIVE!!!!
Get you a.photo shortly lads :)
Thanknyou all sooo much for sticking with me.and helping me.out
What did that mean then,,,, :spin2:
