2001 R1 exup
R1 ROSS
This post is 6651 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
Hi everyone,ive just brought a 2001 r1 and ive got a poblem.when i let of the throttle i get a terrible rattling noise coming from the exup valve ,.When i pull the wire going into the valve it seems to improve the rattle.Any ideas what could be wrong?
  • Admin
Sounds like the cable needs tightening on the servo under the tank. Take the side cover of the exup valve and check that this isnt coming loose too.
It sounds like the vibration is coming from the underside ,on the exup valve itself.Is there anything to be aware of when i remove the cover.Will anything spring off and be lost forever?
  • Admin
Hmm i dont remember there being a spring on there :unsure: Just pretend that there is and you wont have a problem ;)
