dt125 fitting a dt200 or wr head
n!ck
This post is 6357 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
hi
im new to the forum looked on here a few times i have owned loads of yamaha dt125's i am currently building one with a friend and was wondering how easy the wr200 engine or dt200 engine fits into the dt125 any replys would be greatly apreciated my bike is y reg and what year of dt200 or wr200 engine i would need
i have full dep system on my bike will i need to up the jets and if so what size?
thx n!ck :unsure:
  • 1 month later...
I have carried out an engine swap, 100cc in to a 50cc frame. I just used the carbuerettor from the orignal 100cc engine. I don't think you would be able to get the bike to run properly by just up jetting the orignal carb.
Greg
  • 8 months later...
I've heard a bit about this conversion. From what I'm told, the cylinder and head are a direct swap but you would have to up the jetting slightly and also advance the oil pump to suit. Assuming the bike is properly derestricted, I'd start with a 270-280 main jet and work from there. I don't know the size of the pilot jet offhand so you'll need to strip the carb and note this. Go to next size up.
