problems with my yamaha jog RR (50cc)
Kingsize15
This post is 3510 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
I've got a Yamaha Jog RR air cooled and I've put an sports air filter on the standard carb I have adjusted the mixture and now have got the throttle to respond but I cannot go full throttle as it feels like there is no power can anybody shed some light on my porblem.
Thanks
Thanks
It's probably lean at wide throttle openings, could result in a holed piston.
you should fit a bigger main jet and did you oil the filter slightly ?
thanks there's a 62 main jet in the carb as standard and yes oiled the filter and was working fine until you tried full throttle.
