yzf750 engine mods?
sheeny7
This post is 6687 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
Hi all,
Right i'm thinking off some engine mods over winter now i'm
running a full system no exup on it with a k&n and set up on dyno
running about 115bhp.need some tips on some cheap way of getting
more power???Any thoughts??
Heard of putting thunderace top end on or what about fzr 1000
top end???Any one tried this or done some think similar.
Also the famous oil burning now using about 1litre every 1000miles
ish depends on how hard the ride was out.
Whats the best part to renew as don't start doing rings and its
usually the valve guides for example..
thanks for any help dave....
  • 4 months later...
Hi all,
mines doing just over 100 and its standard !! seems a lot of work just to get 10 to 15 more let alone more over that !!
that be great exup freak me email is [email protected]
now ex works engine sounds great but not sure if i'd want the
unrideable bike for the road.
the way its going at mo it just having top rebuild and and maybe
back to local dyno shop as they can play with jetting a bit more
for more horses..
replacing my valve stem seals due to using to much oil and
found that had all ex valves bent and 4 inlets bent and had
to re-sim them all last year and think thats whats caused it..
  • Admin
See if you can get yourself some flatside carbs from a breakers off the SP, you can feed some more fuel in which will add a bit.
