Yamaha XZ 550 clutch
Trev
This post is 6910 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
Hi
Can anyone tell me if the xz clutch is the same as the fz 600 are the same I have seen picks of the 550 clutch and they look the same but conformation would be good? I still have the clutch slip prob with the fz and new parts are so expensive I tend to look for a good alternative first
Thanks
Trev
The steel drive plates might be the same......but I'm not sure about the basket......splined hole in the center could be a different pattern :huh: ....assuming that the clutch dimensions are the same.
Seems a reasonable alternative, but you'd have to compare parts to be sure ;)
