DT125 2007
jayc2012
This post is 4330 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
To make your bike come up????????????
Do you mean come up to do wheelies............or more speed.......or more acceleration?
drop 1 tooth off the front or add 3 to the rear and you get about the same result. That said the front will be cheaper and easier to change back and forth if your going on a long trip where you wouldn't want to be reving so high in top gear. You would probably also need an longer chain to fit in a bigger rear
