First Geared Bike
This post is 4377 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
Hi just bought a Yamaha RXS 100, and must i add what a beautiful bike. but have a problem with the Carburettor the one i had on the bike was leaking through the over flow system. so i bought a new one online and i have fitted it all back up any think i should do before i get the bike running again?
Hi, Not sure what your question is here, but if you have it all back together and it runs RIDE IT, if it don't run then check your carb settings and make sure you have all the cables connected correctly, other than that not much else I can say unless you give more info on any problems you might be having. Stay safe. :jossun:
