how to fit a dt 50 clutch
This post is 6966 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
recently aquired a dt 50 witrh no clutch
i have now bought a new clutch and haynes manual
but how the fcuk do you do a clutch on one without a full stripdown
is it accesible from left side casing or right side casing
if anyone can shed some light on this it will be apreciated
Most Yamaha's have the clutch on the right side of the motor.
Drain the oil, & remove the Right side cover to expose it........your Haynes manual should be able to steer you from there ;)
Clutches are definitely one of the easier items to replace on a bike. B)
cheers dude ill give it a go tomorrow night when i finish work
  • Admin
Have you checked the springs are the right length, and arnt compressing too easily
  • Admin
Have you checked the cable? Is connected properly both ends and isnt snapped?
several things to check really
if you have fitted a new clutch then it will need re adjusting to work properly
this is achieved by turning the screw in the left hand casing until it takes up the play and then backing it off a 1/4 before locking it with the 10mm nut
take any adjustment out of te cable before doing this ie give the cable more slack
if this fails then you have maybe lost the little ball bearing that sits between the pushrod and the mushroom at the pressure plate end
tried adjusting it up too so maybe it is the little ball bearing
allthough i cant see it being that as i never removed the whole pushrod just the mushroom bit
although thats not to say the previous owner didnt lose it as i bought it with no clutch
