DT125R Diving
richy*rocket
This post is 4580 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
Hi everyone,i have a small problem with my 2001 dt125r,
when i use the front brake the front end dives quite a lot, i have changed the fork oil but it has made no difference :bawling:
so do i need new springs or is there something else i should be looking for?
thanks,
Richy
Its normal for an off road type bike to dive like a profesional footballer under braking, unless you hear a clonking noise indicating either hitting the bump stop or a broken spring there is nothing wrong.
Stop riding it like a race bike and learn to balance the braking between the front and rear brakes, the front disk on DT's is shite anyway and fades like cheap jeans so consistent hard braking is not reccomended, you will go through pads and even disks very quickly otherwise.
