YZF750R Float Height
andyyam750
This post is 4640 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
The only data I have doesn't actually list float height only fuel level which is listed as 6.8 - 7.8mm above the lines marked on the bottom of the float chamber by attaching a piece of clear hose to the drain hose union on the bottom of the float chamber and undoing the drain screw and holding the hose vertical by the lines.
