torque specs for xs400?
Rust
This post is 4679 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
Hello again ,
Im still picking at the bike here , and just finished painting the down tubes. I'd like to know the torque specs for the front wheel? There is one 7/8 Nut on one side where the pin goes through , and two 9/16 nuts on the opposite side. Should i use locktight?
'79 xs400
right on , thanks.
Hello again ,
'79 xs400
right on , thanks.
72 ft lb for the big nut (no not you!)
for the 13mm nut clamp;
make sure the arrow under the clamp is facing forward, they are slightly sloped because you tighten the front one up first to 11 -18 lbsft then the rear which there should be a gap left. This acts like a spring keeping the axle and nut in place.
I use aero nuts on mine but not really necessary
drewps
