Smoking dt50 problem
dtandy
This post is 7124 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
hi I'm new to this, but can you help me I just bought a 1998 dt50 and it's a little cracker!
I have a problem in that it is smoking excessively, it was fine when I bought it and tested it. I noticed that the oil in the gearbox was low so I got some oil and topped it up and now the bike is smoking badly.
Can anyone help and give some idea what the problem is and how to fix it.
:? thanks
Skyline's got a good point I think.
2 stroke engines do smoke and the less you use them the more they smoke.
Using a cheaper mineral based oil like valvoline will make the bike smoke a lot but the smell will not be the same as engine oil.
Unless you think it's gutless then it's probably the 2 T oil.
Is it really really bad or is it just that you notice it?
Did you add ATF to the gearbox?....or 2-stroke oil to the resevoir?
It could be a dodgy crank seal, leaking gearbox oil into the crankcase :?
