yamahaman2 Posted October 24, 2010 Share Posted October 24, 2010 hey guys new here, i have a 78 xs400. the carb boot vacuum nipples are connected to each other with tubing that is pinched off. this seems incorrect, anyone care to help? wondering how they should be connected because my idle is rough and my accelaration is nill. Thanks Link to comment Share on other sites More sharing options...
HoughMade Posted October 25, 2010 Share Posted October 25, 2010 They should be blocked off, capped, unless you are using the original vacuum petcock. If you are, one should have a vacuum line to the petcock, the other should be capped. As for your rough idle. Clean the carbs well, then balance them...and you can't balance them if they are connected. Link to comment Share on other sites More sharing options...
yamahaman2 Posted October 25, 2010 Author Share Posted October 25, 2010 how do i seperate the stator from the inside of the housing? took out the three screws and it seems like it wont budge. Link to comment Share on other sites More sharing options...
HoughMade Posted October 26, 2010 Share Posted October 26, 2010 Sorry, I never have. You may want to start a new topic or jump into one that deals with the stator, otherwise, the people who know may not look in this topic. Good luck! Link to comment Share on other sites More sharing options...
Moderator drewpy Posted October 26, 2010 Moderator Share Posted October 26, 2010 how do i seperate the stator from the inside of the housing? took out the three screws and it seems like it wont budge. 3 screws inside and 3 on the outside to hold the field coil (they are connected) the stator coils need a bit of persuasion! Link to comment Share on other sites More sharing options...
