DT 175 Rear Fender
CameronMac
This post is 5216 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
What fender is on it now? I suppose any old fender would do for an off roader. Have the bike still got the bit of fender (black plastic0 that the swing arm passes through. this is the front part of the rear fender. then the seat base forms the top part. Finally the two piece rear part has a plastic top and a steel under section to take the weight of the rear light unit.
As far as replacing the rear section its your call really so long as it is fastened securely and will hold a light / licence plate unit if required.
Have you got a parts book? you can download one go the workshop 'sticky'
As to the question though i dont know if it will fit youll have to try it and see.
...Paul
