'76 XS500C crankshaft replacement?
bwellervt
This post is 5402 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
Hey Guys,
So, I'm working on my old XS500, this being the same bike I posted about earlier with the missing tappet adjustment screw and bad vibrations.
As expected, the screw wound up somewhere bad: the LH crankcase cover. Destroyed the balancer chain, broke the idle shaft bracket into 3+ pieces, and sheared the teeth right off the balancer drive sprocket that is built into the crankshaft.
The helpful soul who responded to my last post mentioned that I could run w/o a balancer. Is this a crazy idea?
My other, and more preferred option is to replace the crankshaft and get that balancer spinning again. I've already got a replacement balancer chain and idle shaft bracket.
Anyone have a crankshaft for my XS500C they could part with for a reasonable price?
Thanks in advance for any advice or help finding parts!
-Ben
