Mosher Morris Posted May 30, 2009 Share Posted May 30, 2009 hey all just a bit of advice really, i rather devastatingly dropped my bike (but thats why have 125 so hopefully i dont do it with something bigger when the time comes) and the right rear indicator has come off any ideas whats best to stick it back on with, all it is is the bolt has come out from inside the indicator itself so if i can get the stuck back in jobs a good en cheers for any suggestions Link to comment Share on other sites More sharing options...
uzi_999 Posted June 5, 2009 Share Posted June 5, 2009 hey all just a bit of advice really, i rather devastatingly dropped my bike (but thats why have 125 so hopefully i dont do it with something bigger when the time comes) and the right rear indicator has come off any ideas whats best to stick it back on with, all it is is the bolt has come out from inside the indicator itself so if i can get the stuck back in jobs a good en cheers for any suggestions as far as i remember, the 07 models, had the 'wibbly wobblies' on, theyl just bend and get back to normal.. theyre held in place by a little oval shaped washer thingy.. i assume your ybr is the type with the hard plastic shaft indicators.. i suppose if you can open the indi unit, and somehow remove the old nut, place a new one in there, and push it thru the mudguard bit, and bolt on other side.. or the easier way, a second hand indicator from good old fleabay Link to comment Share on other sites More sharing options...
