front wheel judder
liquidcooled
This post is 7282 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
when i take my hands off the bars the wheel judders a bit, i'm thinking steering head bearings, could it be this? tyres are fine so cant be that :?
  • Admin
Should do it on breaking as well if its the steering head
Are you referring to your XJ there Alan?......'Cause I thought you had this prob sorted with your RD :?
Either way mate, don't skimp & get Tapered Roller Bearings put in that Headstock......You won't regret it! :wink:
yeah it's the xj scott. the rd got a set of tapered bearings in it, what an improvement, silky smooth 8) not sure what the xj has in it, hopefully just need adjusting.
I put Tapered Rollers in my old XJ 550 Seca.......with Killer Results 8)
Maybe just Repack 'em with fresh grease & an adjust will do the trick? :wink:
yeah mozzy i was thinking the same thing mate, i'll try the steering bearings, if that fails i'll see if the wheel's balanced properly :wink:
