manchester bike show 22nd and 23rd march
which one then?
DT in distress part 3!
dont think it's a full strip dt...just the clutch case off maybe?
Hi
What is the world coming to? Hardly...It was just ONE word misspelt ! Thats some exageration there feliks
Greeting
lol, thats a small hi big HI to you too Foxxy
Hello all
Greetings John
Hi
a simple spelling mistake Mike, all that other stuff is optional! let me quote the message under 'New Members' from Alex This is it... "If this is your first time, come on in and introduce yourself or just say hi." so it can be seen that kat fulfills the necessary criteria, lets put an end to all this noob criticism! Greetings kat like blackhat says, any constructive and/or humorous input is
xvs 125 rear spindle question
I think he means the spacer in the hub, the one between the bearings, yes kepeg it needs to be there...get a new one bought if you need to
SR125 MOT failure today �
binding brakes is very often the sliding caliper isnt sliding any more!
1988? Yamaha DT 125 worth the time and money?
you have 2 screws, The big one is idle speed adjuster, the small one is mixture. Big one...screw clockwise to increase rpm Small one screw clockwise to richen the mixture
Damn. Both bikes down now
might have starvation issues with high loads, float valves come in various sizes, is there a number on the seat somewhere...how do the numbers compare?
Trouble changing brake pads on a 07 DT 125 RE
you might find it easier if you have the caliper mounted loosely on the bottom mounting bolt
so is there gap between the pads that's big enough to accomodate the disk?
you need the force the piston back into the caliper a little, isnt it obvious?
hello all:)
Greetings badger...how was the cull fella, lose any loved ones???
xt550 holding back
There may be a fuel filter screen in the carb float valve seat, there may also be a filter screen inside of the fuel tank...check these are clean Hey Yamahead It's nice to see you back on the forum
2 Stroke gathering and YOC camping weekend 2014
Wrong...that is oldtimer
out with the flat slide carb dt125r ??????
I meant look in the for sale section but I see you already have, I'd also sent AndyDTR08 a PM in case he misses you question but he isnt here that often so you may have to wait, theres also the DTR forum...ask NEV
The earlier DTRs had a round slide carb I think, if it were me though I'd stick to the flatslide as was intended, is yours goosed then? cant you get one from ebay? or someone here
Parts needed fast!!
nothing more than nipping it up, I suppose the rubber seal / O ring will keep it in place
Remove the petck first in case there is a filter screen inside of the tank It's a good enough method
Thats a good way to do it jake, fishtank gravel
happy to be here
Greetings satchumi, good luck on getting her fixed up
Velocette LE annual rally, Astley Collery 6th July
I've ridden one of those things...not exactly a looker are they but hey they have an interesting specification for when they were made
Clean the original either ultrasonic of the best you can do with carb cleaner and compressed air...save your money if the carb is only dirty
when the dog stays at home alone
