		Indicator faults
		If you fit led's and you dont replace the relay with an electronic relay, then you will need to fit resistors to give enough current draw to operate the bi-metallic strip as found in the original relay There...simples
		Indicator faults
		it needs a proper led relay fella, I just bout a cheap chinese one with adjustable flash rate it seemed good for the money , dont know how it woulf fare on a bike but for that money it's gotta be worth a punt http://www.ebay.co.uk/itm/380898229899?_trksid=p2059210.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT#ht_5345wt_1310
		1980 DT175G Running Problems (US Model)
		see here for exhaust restriction elsie
		DT125E 1977 1G0, Not able to find manuals for this mc
		The manual shows a 12v battery (6 cells) so where did you get this 6v idea from?
		2 days past my cbt and already addicted to riding lol
		course we will dave, welcome in fella it's great to see the enthusiasm.
		Yamaha xt 125 x problems running
		yeah maybe a new battery?
		yamaha ag 175
		hey thats looking good mate
		hey norway1 you have a PM
		2 Stroke gathering and YOC camping weekend 2014
		Ray all the best to your eldest lass and saturday, is the wedding soon?
		New DT125Enduro Rider from Norway
		Greetings mate, I've a look around and havent seen any trace of manuals but I've put some feelers out
		look what I found!
		so keeping with the classic moped theme and since Harley was mentioned...TaDa...Harley moped a snip at £3250 lol http://www.ebay.co.uk/itm/1965-Harley-Davidson-M50-Aermacchi-taxed-and-mot-with-log-book-rare-collectors-/161410711015?ssPageName=ADME:SS:SS:GB:1120#ht_0wt_0
		Croatian biker
		Greetings elezdee, nice to see you in here, yeah join in the fun...perfect intro
		look what I found!
		yeah see that before it sounds awesome
		DVLA stupidity!
		Dohh my head hurts!!! Damned frustrating mate. is this affecting your squires mount?
		curry on Saturday? Me, Drewpy, Bippo, Finnerz, Tommy anyone else?...
		YX600 carb mixture
		yeh but my TTR is different, its an air screw between carb and engine!
		"77"dt175e very weak spark  source coils on stator plate problem  shes a non runner at moment
		Hi shaun have a read of this fella DT175MX Ignition checks There were two versions of ignition systems on DT175MX bikes. The mk1 version from the earlier bike had a 7 wire CDI the early bikes had a round section swing arm. The mk2 version had a 6 wire CDI, the red wire is absent on these. These bikes have a square section swing arm. The HT cap (AKA spark plug cap) unscrew it off the HT lead, it is supposed to be a resistor cap so should be around 5K Ohms The ignition coil primary...Orange wire to battery neg should be 1 Ohm +- 10% The ignition coil secondary...HT lead to battery neg should be 5900 Ohms +- 20% If the readings are much higher, check the ignition coil has a clean ground connection. Yes and the ignition coil mounting is a wiring harness ground point too, so check its clean and bright there. Disconnect all the wires from the CDI. Then using your multimeter on the loom side of the connectors. Black probe on a clean part of HT coil ground point Red probe on...... Orange, Meter to 200 Ohms, expect 1 Ohm (HT coil primary) Brown, Meter to 2k Ohms, expect 420 Ohms for mk1 and 300 Ohms for mk2 (Magneto charge coil) White/Red, Meter to 200 Ohms, expect 12.4 Ohms for mk1 and 10 Ohms for mk2 (Magneto pulser coil) Red, Meter to 200 Ohms, expect 13.6 Ohms for mk1 only. (Source coil 2 or high speed coil) Black female connector, Meter to 200 Ohms, expect dead short repeat for black male connector Any difference in the results for the two black wires may possibly be rectified by cleaning the front engine mounting bolt and a little of the frame behind the bolt head, then tighten to torque spec. Black/White, Meter to 20K Ohms, with ignition off expect dead short, with key on expect open circuit, with kill operated expect dead short (Engine kill operation) If all these tests are good you would be well advised to try another CDI. If they are not good...reading higher...disconnect and clean any plugs/sockets you find along the way, if the magneto coils are reading lower, new ones needed if more than 10%...or so the book says Finally, if you are working with a box full of mixed parts! Mk1 1 flywheel is Mitsubishi F3T250, it has two slots in the face of the flywheel Mk2 flywheel is Mitsubishi F3T251, it has four slots in the face of the flywheel
		struggle to find 3rd.
		dont like the sound of this...dont mess with it under warranty
		XJ 600 diversion help
		chances are one of the pilot jets has clogged up, thats what happens when you dont use them enough...you may be able to pinpoint the offending carb from the heat of the exhaust headers when you first start her up?
		help needed on 2 stroke
		to test that theory, just get a length of wire and bare both ends, trap one end behing an engine case screw and the other behind a screw on the frame ?
		arrow exhaust running lean
		this is the new members intro area Problems with you bike would be best posted in the workshop forum !
		Fork seals which way round xt125r 06
		I've never seen fork seals with the spring showing on top for what it's worth.
		Yamaha fan bought a 2015 SR400
		Welcome in bob, really like your bike fella, glad you got another just like way back
		Bloody Hell!
		look what I found!
		yeah i'm out too, i was going to ask ddt about the import issues and yeah I feel the same as him now ...was kinda hoping for a nice black and silver stamped reg plate hanging off the back...damn!!
_33963e.png)
    _83bc35.png)
    .jpg.6e6eb167e0a6dff4733f27bedaf16390.thumb.jpg.c2d8f053e6a294f4d70a79bd2bdaa623.jpg)
