Need help identifying bike
I make it XS500F 1978 Austin.
Umm hey
Greetings Dan The R1 is far too powerful for umm...a 19 year old so stick with the R6,
DTR 125 Head Gasket Issues
Good advice Tony, some nuts can be torqued but the DTR gives too little clearance for sockets on some cyl head nuts, so a little guesswork with a ring spanner has to be applied. DTRs are renowned for blowing gaskets and so I will say again a thin line of silicone around the bore circumference (just 7mm wide) is of benefit and it cleans off quite easily,
1974 dt250a
I cant understand how it was dry unless the oil level was extremely low?
HELLO! new guy here :)
Greetings matt Hairspray...well I suppose it's appropriate for a aerox hairdryer
New Guy From Florida
Greetings Florida Joe
XVS 125 - Problems starting with a hot engine.
Either the air filter is dirty...or you are using the choke?
Even a cheap one may work with the film of silicone as I said...I fitted it dry
I have used a cheap one once and sure enough it failed. I use proper ones now and run a thin film of silicone manifold sealant around where the bore is only about 7mm wide not the whole gasket (you have to get it off again sometime) do this both top and bottom. Your head may be warped though I cant comment on that but skimming should be done proffessionally in my opinion. At a guess place the head on a piece of glass and ensure it doesn't rock in any way.
are you using a cheap after market all metal gasket or a pukka yamaha rubber coated one?
Tech Question
I,m having similar problems with my bandit, looks like i'm hading for a carb strip as two cylinders are not getting hot at the headers and thay are not common to one HT coil
New bike owner
Greetings Nacho
Morning all
Greetings Terry from Staffs
Hi there
Greetings Ian theres no way on this earth that a virago 125 puts out 33 bhp
Hi all
Greetings tone, have you tried councelling?
Just want to say hello
Greetings Bernies son
- hello
DT 175 MX Engine Rebuild
125's have one less friction plate, and generally look different
Hello everyone
Greetings Mark TDR 125...what an awesome little bike they are you lucky g1t
DT 175 MX Rebuild/Electrics
Not sure on the switch issue but there are two versions of CDI, one is 6 wire and one is 7 wire, the presence or absence of a RED is the difference, early bikes had two source coils in the magneto...the RED connects to source coil 2 on these.
Hello
Greetings oneowl plenty of XS400 expertise and interest in here mate.
Newbie in everyway!
Greetings Tye Every time I see one of these babys I cant believe they are only tiddlers. Look forward to seeing your progress with this.
Hello, new member here.
Greetings 'Wings' aye we loiks enduros ere
Spark Plug grade TZR125 (ypvs fitted)
Sounds good to me.
hi guys im new and need some help please
The other two wires Blue and Black are for the meter light so leave them be, you are only concerned with Blu/Red and Blk/whi If they are shorted disconnect them, if they are not shorted then short them. I advise that whatever you do try to do it in such a way as to not damage the wiring, like short them in the plug for exaple rather than chopping your loom.
