dt spokes
i got mine made in stainless steel at manchester xtreme, in fact just over a year ago spokes and re-build for both wheels cost me £120 http://www.manchesterxtreme.co.uk/clothing.html
new hull - just got first bike
Greetings jamie
rxs100 revs high then loses power and cuts out
sometimes you can get away with a gentle tap to the float bowl to re-seat the valve, try this to see if you are lucky it sometomes works, dont hit it with anything metallic or you will mark/damage it!
whats overflowing, the carb? if so its more to do with float height setting or a stuck/dirty/worn float valve
6 volt Voltage reg,
for years i have used one of these on mine, i like them more because the cable just plugs on instead of being a fixed 'potted' cable so if the cable breaks It's not a big deal...DT50 i believe
Hi All - Sr125 Clutch cable adjustment
is there a pointer at the end of the operating arm and a pip on the engine casing? BTW this forum should be reserved for intros
6 volt Voltage reg,
pretty sure it is mate, I'll have a look in my spares department tomorrow
Seized rear light bolts on DT 250 MX - Help!
ok then a more detailed description of 'said' bolts? and what you are thinking of cutting?
6 volt Voltage reg,
is it a single wire AC regulator john?
a pic would help!
Wanted !! has anyone seen this man
Aye me too, i'll keep an eye out for the scoundrel, funny thing is...i'm sure i saw him looking in through my living room window the other night, but when i went outside he had gone
- '78 Suzuki TS250C project
3000 idle, sounds a bit fast? I would have thought 1500 - 1600
- 2002 DT 125R HELP!
you still got this bike mate?
DT 125 1980 swing arm question
2002 DT 125R HELP!
yes but do you know the torque setting, and how are you going to stop the flywheel turning while you tighten it??
the shock will have been changed too unless the width of the original shock bottom pivot was reduced to suit the new arm
YP125 Majesty 125cc wiring diagram
hmmm never seen a haynes manual without wiring diag's yet!
2002 DT 125R HELP!
how are you going to torque up the flywheel nut to the specified torque this time?
Then what is this pray tell ? [url[http://www.ebay.co.uk/itm/Haynes-Manual-Yamaha-YP125-Majesty-YP250-Majesty-/180718630057
do haynes do a manual jon?
so the engine# isnt also 2k4 then ?
PostApocalyptaBike Rises!
Greetings and yeah we loiks piccies
1973 dt250
i think the 50mpg figure would be closer with a motor in good shape
