Gilera 4V project
looks great drewpy, might use the guy myself now then thet semi downdraught carb...whats all that about then
DT 175 MX 12volt conversion
and they are also on when the keyswitch it in the second position (lights on) and so if your headlamp fails you will still show a front light so you can be seen by others
De Restricting my DT125R
yeah if you want any help with yours start a thread of your own but you should find all your info in here
Generator rota removal
dont know the bike sean so without pictures i myself am a bit stuck fella
- 2 Stroke gathering & YOC camping weekend 2012
yes if the exhaust and PV have not been de-restricted
yep it sounds fully restricted to me Steve
sad day today :(
I'll second that Merv, get well soon Kishan and hope that your not hurt bad like Merv said
not technically a new member...
This is it Tobi http://www.google.co.uk/search?hl=en&cp=14&gs_id=8&xhr=t&q=kawasaki+zl900&qscrl=1&rlz=1T4GGLL_enGB401GB402&bav=on.2,or.r_gc.r_pw.r_qf.&ion=1&biw=1024&bih=516&wrapid=tljp1346398207609014&um=1&ie=UTF-8&tbm=isch&source=og&sa=N&tab=wi&ei=BmhAUP_LIu6U0QXVsoDoDQ
Hello
Greetings Lerch, see now you redeemed yourself
Yamaha DT175 'barn find'
batteries arent expensive, Its the battery and a correctly wired regulator that will keep the bulbs from blowing
are you going to be using this on the road then?, How will it pass an MOT with no lights/horn
I assume you will be fitting a battery next, you will need the little fuse that is in the battery + wire as well
That is not the rectifier it is the voltage regulator. The voltage regulator has a yellow/white wire thet plugs into a single bullet socket also yellow/white. It also has a black wire that is secured using a ring terminal around the regulator mounting bolt, this black plugs into one of the black sockets in the pair you mentioned, the black from the battery negative plugs into the other. The other yellow is for the brake switch. Its a bullet socket at the brake switch and bullet plug on the loom
Yeah when you get the multimeter study whats happening by referencing what I have just told you There is a brown wire to the rear brake switch thats correct
The black/white wire to the CDI is the engine 'kill' wire when the keyswitch is off this wire is shorted to chassis also when the keyswitch is on and the kill switch in not in RUN position this wire is again shorted to chassis it follows then that when the keyswitch is ON and the kill switch is in RUN this wire is NOT shorted to chassis what do you mean what is the brown wire coded for? dont understand the question brown wire from/to what?
I take it you have a multimeter?
hi from new member
Well done Alex, Spain...now thats gotta be a great place to ride the SR
old newbie
welcome back Mo, got some catching up to do, a Z900A.......Verrry nice
'78 Suzuki TS250C project
ive got a #190 and a #195...not got #200, next bigger is way too big at #250
is it a mikuni carb DirtyDT? I have some hexagonal jets are these the right ones...what size is fitted at the moment?
- New Bike
