Just Picked up a 1978 IT 175: What are some common mods?
First post and not so much as even a 'Hello'
DT 125 missing part
Well said that man, poeople but time and effort and even research into answering posts in order help to solve problems. I have done it myself many many times, it used to get my goat too NEO, keep going to the seemingly urgent request for help, only to find still no reply.
R6 problems any advice would be appreciated!
If it is blocked you may hear a rush of air into the tank as you open it, or it may restart quickly, if so it is up to you to find out why, i'm no R6 expert and I'm not suggesting you should ride with the filler cap open
Another tank vent problem? Try opening the filler cap when she dies, does it re start then?
Bike Quits
Tank breather trapped, blocked or otherwise ineffective? Try opening the gas cap when it 'quits' and listen for a rush of air, see if it will re-start quickly. Hello and welcome, we have a 'Noobs' forum if you please My name is Paul
Please.................................. Thanks
? err yes
Evening from sheffield
, nuff said
jog 50 rr need help
Could be a broken, leaking or otherwise disconnected vacuum line between the fuel tap and the inlet manifold. That is assuming that this ped does indeed have a vacuum operated fuel supply....not familiar
Greetings fli , looks cool. Had it long?
jog 50 rr need help
what is the recent history to this 'not starting' ? is there a good spark?
back into bikes
Greetings, another 2 stroke DT fan where are you...USA?, teardown and 78 dt250 sound like American ways of saying things ...Paul
2 Stroke rev problems
yes the only way petrol gets in there is through the seal.
Virago XV 125 CDI Unit repair
Great little problem solve, hats off to you sir. (RS is a good source for these kind of widgets)
That Time Of Year Again
Its a chopper alright
new lady owner of an R125!
Greetings Rutele and to the forum
YBR 125 5th to 4th gear shift noise
Try increasing the revs with a little 'blip' of the throttle during ANY downshifting (not up shifting) it helps a lot
tank bolt stuck sr 125
Back in the day when I had 4 strokes the adjuster went through one end of the rocker arm and pusshed down on the valve stem, the gap was set between the adjuster (tappet) and the valve stem and then the little locknut done up afterwards. This has to be done at definite pionts on the engines rotation and may co-incide with marks on the flywheel rotor. of course since then many bikes have moved to shims for adjustment...never done one of those.
Site will be down this weekend
OK thanks for the heads up Alex, from when?
Noob meets Vintage
Greetings, Looks like you got a great example there, a picture?
Went for a ride on the dt...
- Dt125 starting/running issues
There should be no resistance through a non suppressed plug cap, yours must have a loose connection and is best replaced, also the ig primary is low as you say so youre doing right by replacing both IMO- I have a bit of a headache after an incident this morning.
Aghh the sting in the tail I thought the beer was only a few shillings- DT50: Don't call it a moped
Sweet little DT you got there, waddya mean no need for insurance...surely not a field bike ending...Tsk Tsk- DT 175 MX cylinder barrel
I wouldnt , unless its for an early bike. My guess is it's for one of the later models and may not fit.- Went for a ride on the dt...
So you really have got a bike, I was beginning to wonder Nice, fast too by the sound of it...is it a keeper now? - Dt125 starting/running issues
