Airhead
  1. depends on your neighbours
  2. Greetings Joe
  3. just hold the pulley fully turned when the engine is idling, you'll see the oil moving through the tube in pulses, travelling about 6mm each pulse. Forget about the pressurising idea...no need
  4. greetings spooks, heated vest lol...not Scottish then eh
  5. a picture of loch Ness or a picture off facebook? yep its been pretty good Sept John
  6. regarding the cylinder sleeve nut Always use a 6 point socket on these aluminium nuts, never use a 12 point one so get the correct sized 6 point one, shove a strip of medium / coarse grit emery cloth into the socket and tap it down onto the nut...blowtorch the side of the nut to get a bit of heat into it and try again
  7. Give 'TY Trials' a ring Dave
  8. yeah there's bound to be some play after all those years, there are rubbers in there, myself I wouldn't bother...cant see why you'd think it's causing a knock just because the rubbers will be a little eroded?
  9. Greetings Craig, some great Yamahas you've got there fella
  10. sorry, I dunno about that one
  11. the orange coloured stuff
  12. Unusual to see one fail Nigel,it's normally the cable that breaks...I'd say take the cable off and inspect the inner cable?
  13. did you clean the cases in the dishwasher.?..Top Tip
  14. it sounds like the crankcase is flooded, turn off the gas, take out the sparkplug and spin the engine over to eject some of the fuel, than leave it overnight to evaporate off...that's what I'd do anyway. hey, first post all about a problem!...what no intro / hello?
  15. check someone hasn't put a 12v bulb in the headlight
  16. it should come on when the engine is idling albeit a bit dim...but nevertheless it should come on. is the battery new or how old is it?
  17. so did you check the switch is working? did you disconnect the wire from the switch and touch the engine casing or chassis bolt with the wire?...that would test the bulb/socket and may even point to a faulty switch
  18. Airhead replied to MTNMOJO's topic in Classics
    to upload a picture you need to use a hosting site such as 'Photobucket'
  19. Airhead replied to MTNMOJO's topic in Classics
    how about this, no battery needed
  20. Airhead replied to MTNMOJO's topic in Classics
    what is on the stator plate...is it a points ignition bike or a cdi ignition? state the colour of the wires
  21. Greetings Jason
  22. blackhat was faffing about with his helmet so I chose this one
  23. I suppose all the connectors to the ignition module are clan and good?
  24. if I,m not mistaken theres a filter gauze attached to the float needle valve seat, check its clean. If it's mucky it will give those symptoms.
  25. Greetings Big Dave
